NEOTECH NEUB-1020 Cable USB-A Male/USB-B Male 2.0 Gold plated 24k Silver 1.5m
The Neotech NEUB-1020 class 2.0 AUDIO USB cable offers a formidable digital reproduction quality using innovative technologies that shake up the hierarchy of high-end USB cables. Designed with pure silver OCC monobrin wires for each DATA + and DATA part - this cable contains treasures of sound fidelity with a high-end polyethylene sheath and 100% EMI shielding. This USB cable has optimized gold-plated USB plug.
Reference : 12156
199,00 €tax incl.
165,83 € tax excl.
Shipping date: 21-04-2026.
Neotech NEUB-1020
Male USB-A to Male USB-B 2.0 Cable 24k Gold Plated UP-OCC Silver 1m
Neotech NEUB-1020 Câble USB-A Mâle vers USB-B Mâle 2.0 Argent UP-OCC Plaqué Or 24k 1m
The OCC process allows to obtain a larger and purer crystal, with a purity rate of 99.9998%. This ultra pure conductor ensures a cable with low electrical resistivity, higher signal transmission speed and greater resistance to twisting, oxidation and corrosion.
Cable typeMale USB-A to Male USB-B
Conductors materialSingle crystal UP-OCC pure Silver conductor
Connectors platingGold 24k
External diameter6.2mm
Shielding100% shielded cable. Eliminate EMI interferences.
InsulationHigh Quality Polyethylene
Length1m
Cable colorWhite / Silver
certificat d'authenticité Argent OCC
Length (m)1.5
ShieldingYes
Section (mm²)N/A
ConnectorUSB-B
ConnectorUSB-A
Conductors material (Cable)Silver
6 reviews
Wonderful
I must admit that I was not familiar with this brand of Hi-Fi cables.
Having purchased from this site for years and knowing the average quality of the products distributed, I decided to buy this 1.5 m USB cable.
The construction appears flawless: the cable is covered with a white, fire-resistant textile material, making it very flexible and suitable for use even in small spaces. Both the USB-A and USB-B terminals are gold-plated and fit securely into the outputs of both my DAC (Denafrips Pontus 15th) and my streamer (Rose 250). In terms of sound quality, it was a pleasant discovery: crystal-clear high tones that are never annoying, full-bodied but not redundant bass, clear vocals, and excellent separation of instruments. High data transmission speed.
Overall, a cable with an exceptional price-performance ratio.
I recommend it without hesitation to anyone who needs a high-quality USB cable.
Fast and flawless shipping, something I have always appreciated about Audiophonics.
This review has been posted for NEOTECH NEUB-1020 Cable USB-A Male/USB-B Male 2.0 Gold plated 24k Silver 1.5m
Câble USB avec un rapport prix qualité excellent
Quand j’ai lu certains avis et étant dans le même cas que certains (câble hors de prix d’une grande marque américaine), je me suis lancé et commandé. Assure la liaison entre streamer Eversolo et DAC Gustard R26.
Je souscris à la plupart des avis, ce qui surprend par rapport aux différents câbles que j’ai pu avoir, sur une tranche de prix généralement supérieur, c’est à la fois de la subtilité, de la finesse, de la fluidité et une écoute davantage rythmée et dynamique. C’est une présentation ouverte, élégante, d’une grande transparence, tous les registres sont bien restitués avec un aigu d'une grande beauté très clair. Dépasse largement le dernier que j’avais qui n’était pas 100% argent (un mix argent/cuivre) de la célèbre marque US , ce dernier coûtait plus de deux fois le prix de ce Neotec.
Conforme
Câble conforme à mon attente, n'est pas fait de comparaison mais semble dans le haut du panier.
Excellent
Après une semaine d'écoute, des apports flagrants. Une très grande homogénéité, de la dynamique, des détails, mais pas assenés, une grande limpidité. l'impression générale que tout y est et dans le bon ordre. Rien non plus d’exagéré. Malgré la bonne qualité de mon câble précédent d'une grande marque américaine, c'est bien mieux et je ne pense pas m'en lasser. La question que je me pose est : vais je continuer mon projet de changement d'ampli, car après tout maintenant, cela passe très bien et beaucoup plus propre. Même si j'en étais convaincu depuis longtemps, je suis encore surpris de voir ce que peut amener l'optimisation de la source, y compris en numérique
 (4)
l'argent sans les défauts de l'argent
Ce cable argent OCC vient en remplacement d'un Atlas OFC cuivre, très haut niveau de détail et de subtilité avec douceur et sans manque dans le bas. Je ne constate pas les défauts de cables argents qui peuvent sonner sec et manquant de liant. En usage avec Labtop, M2tech hiface, ampli triode SE. COmparé avec un Zavfino cuivre OCC beaucoup plus 2rentre dedans" et mat dans le medium, le neotech sort grand gagnant.
 (3)
The Neotech NEUB-1020 class 2.0 AUDIO USB cable offers a formidable digital reproduction quality using innovative technologies that shake up the...
