DIY Male USB-C 3.0 Connector Gold Plated
This USB-C male connector will allow you to design your own cables. These take advantage of gold-plated contacts on the USB-C connector side and copper alloy solder pads.
Reference : 15793
1,90 €tax incl.
1,58 € tax excl.
Shipping date: 26-05-2026.
USB-C Connector
Male USB-C 3.0 Gold Plated DIY
Connecteur USB-C 3.0 Mâle Plaqué Or DIY
Product typeUSB-C Connector
ConnectorMale USB-C 3.0
Contacts platingGold
Mouting typeTo solder
Max cable diameter (mm)N/A
Mounting typeTo weld
ConnecticMale
ConnectorUSB-C
Easier to use as it seems
I use this between my dc cable and the iFi iDefender, so only the dc is connected. Although this usb is very tiny, soldering the wires and putting the plug together was easier than I initially thought it would be. Use heat shrink tubes to finish it.
This review has been posted for DIY Male USB-C 3.0 Connector Gold Plated
This USB-C male connector will allow you to design your own cables. These take advantage of gold-plated contacts on the USB-C connector side and...
