Adapter Impedance Transformer AES/EBU 110 Ohm to Coaxial BNC 75 Ohm 0.1 - 6.0MHz 5V
This impedance transformer adapter converts the two AES/EBU digital audio channels 75Ω into a coaxial signal 75Ω. The input connector is XLR3 female and the output connector is BNC female. The adapter has a bandwidth of 0.1-6MHz and a maximum voltage of 5Vp-p. It complies with the SMPTE 276M and AES3 transmission standards.
Product type | Adapter Impedance Transformer |
Input | Female XLR3 AES/EBU 110 Ohm |
Output | Female Coaxial BNC 75 Ohm |
Transmission standard | SMPTE 276M AES3 |
Bandwidth | 0.1 - 6.0MHz |
Max voltage | 5Vp-p |
Dimensions | 83 x Ø20mm |
Weight | 48g |
Connectic | Female |
Connector | XLR |
Connector | BNC |
Contacts Material (Connector) | Copper Alloy |
Contacts Plating (Connector) | Gold |
Contacts Plating (Connector) | None |
