Ground Noise Suppressor
When you touch the chassis of your audio device, does the hum / sizzle increase? If this is the case, it is probably due to a lack of grounding, which protects your system from interference. Current electrical standards require certain precautions to be taken that are not necessarily in line with the concept of audio performance. This can result from noise or blast due to interference.
With this in mind, iFi Audio decided to launch GroundHog+, which allows you to make an effective grounding that will greatly reduce interference from your audio system. The product is also delivered with several accessories to make it compatible with all types of power supplies on the market:
The iFi Audio GroundHog+ for even greater noise reduction can be associated with the sector filter iFi Audio AC iPurifier (sold separately) thanks to the RCA / banana core. This way you can enjoy the benefits of GroundHog+ while limiting external interference.
To find out if GroundHog+ could help make your audio system more efficient, it's easy. Just follow the advice in the diagram below. If there is no or insufficient mass, it is recommended to turn to GroundHog+. In case of a ground loop, it is preferable to integrate the iFi Audio iDefender 3.0> into your system.
Product type | Ground noise suppressor |
Packaging | 1x RCA Cable 1x USB Converter cable 1x Spade converter cable 1x Y 3.5mm converter 1x Banana / RCA cable |
Connectic | Male & Female |
Connector | Banana / Spade |
Connector | RCA |
Connector | Banana |
Connector | USB-A |
Contacts Material (Connector) | N/A |
Contacts Plating (Connector) | Gold |
