LDOVR LT3045-LM31X Ultra Low Noise Voltage Regulator +5V
The high quality LDOVR LT3045-LM31X regulator provides a very low noise level (0.8%Vrms) and a very low pressure drop (low-dropout). This model is compatible with the LM317 regulators and is therefore an ideal replacement solution.
Reference : 16199
25,90 €tax incl.
21,58 € tax excl.
LDOVR LT3045-LM31X
LDOVR LT3045-LM31X Régulateur de Tension Linéaire Ultra Faible Bruit +3.3V
Product typeLinear voltage regulator
Output voltage+5V
Output current500mA
Input voltage1.8V to 20V
Dropout voltage260mV
RMS Noise0.8µVRMS (10Hz-100kHz)
Spot noise2nV/√Hz @ 10kHz
PSRR76dB @ 1MHz
ProtectionsFixed current limit
Thermal shutdown
Operating temperature range-40°C / +125°C
Dimensions PCB25.4 x 15mm
Output voltage (V)5.0
Output current (A)0.5
Input voltage (V)2.0
Input voltage (V)20.0
The high quality LDOVR LT3045-LM31X regulator provides a very low noise level (0.8%Vrms) and a very low pressure drop (low-dropout). This model is...
