IEAST OLIO Receiver WiFi 2.4G/5G DLNA AirPlay 2 Bluetooth 5.0 24bit 192kHz White
With the Olio, iEast offers a compact and powerful wireless audio receiver that works with both WiFi and Bluetooth. Extremely versatile, it supports numerous transmission protocols such as DLNA, AirPlay 2, Spotify Connect, Tidal Connect, and can even be controlled through Amazon Alexa and Siri voice assistants.
Reference : 16063
89,00 €tax incl.
74,17 € tax excl.
Shipping date: 15-09-2026.
iEast Olio Receiver WiFi 2.4G/5G AirPlay 2 DLNA Bluetooth 5.0 24bit 192kHz White
Récepteur WiFi 2.4G/5G AirPlay 2 DLNA Bluetooth 5.0 24bit 192kHz Blanc
With the Olio, iEast offers a compact and powerful wireless audio receiver that works with both WiFi and Bluetooth. Extremely versatile, it supports numerous transmission protocols such as DLNA, AirPlay 2, Spotify Connect, Tidal Connect, and can even be controlled through Amazon Alexa and Siri voice assistants. Via the iEast app, it also allows you to enjoy the most popular streaming services such as Spotify, Deezer, Qobuz, Tidal, Amazon Music or many web radios via TuneIn. The Olio's output is on a common 3.5mm jack and Mini Toslink connector. It integrates a Burr Brown DAC chip allowing to perform the digital to analog conversion and supporting sampling rates up to 24bit 192kHz.
IEAST OLIO Récepteur WiFi 2.4G/5G DLNA AirPlay 2 Bluetooth 5.0 24bit 192kHz Blanc
Many possibilities
Versatile, the IEST Olio allows you a multitude of installation configurations within your Hi-Fi system. With its optical/analog stereo output, you can connect it directly to active speakers, an amplifier or even a DAC to broadcast your audio source remotely.
IEAST OLIO Récepteur WiFi 2.4G/5G DLNA AirPlay 2 Bluetooth 5.0 24bit 192kHz Noir
Product typeWireless receiver
DAC ChipBurr Brown PCM5121
ConnectivityWiFi 2.4G/5G IEEE 802.11a/b/g/n/ac
Bluetooth 5.0
Outputs1x Jack 3.5mm / Optical (Toslink/Mini-Toslink) (shared output)
WWA SupportAlexa support
Supported sampling ratesPCM up to 24bit 192kHz
Supported transmission protocolsDLNA
AirPlay 2
Spotify Connect
Tidal Connect
Hi-Rescloud
QPlay
Supported streaming servicesSpotify
Deezer
Qobuz
Tidal
Amazon Music
Napster
Pandora
TuneIn
Supported audio formatsAPE, FLAC, MP3, WAV, AAC, AAC+, WMA, ALAC, AIFF
SNR108dB
Supply voltage5VDC 1A via USB-C
Dimensions54.25 x 54.25 x 13.45mm
ColorWhite
Package1x iEast Olio
1x USB-C cable
1x Jack 3.5mm cable
InputWiFi
OutputJack 3.5mm
OutputOptical Toslink
DAC / ADC ChipBurr Brown PCM5121
Max sampling rate192kHz
ColorWhite
Remote ControlControl app
Transmission / Reception protocolWiFi
Transmission / Reception protocolDLNA
Transmission / Reception protocolAirPlay
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsSpotify Connect
Streaming services & Network protocolsDeezer
Streaming services & Network protocolsTidal
Streaming services & Network protocolsWeb radios
Streaming services & Network protocolsTidal Connect
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsAmazon Music
Supported Bluetooth codecsN/A
Mini Streamer au rapport prix/musicalité étonnant
Relié en Wifi à ma box et alimentant une paire d'enceintes amplifiées, ce streamer fait bien le job: transparent et musical, compact, appli bien conçue. S'assurer d'avoir un bon signal Wifi car le raccordement filaire à une box ou un switch via une prise RJ45 n'est pas disponible.
This review has been posted for IEAST OLIO Receiver WiFi 2.4G/5G DLNA AirPlay 2 Bluetooth 5.0 24bit 192kHz White
With the Olio, iEast offers a compact and powerful wireless audio receiver that works with both WiFi and Bluetooth. Extremely versatile, it...
