Bluetooth Receptor 5.0 AptX HD CSR8675 to Coaxial en Toslink SPDIF
Bluetooth Audio Receptor 5.0 AptX HD CSR8675 to SPDIF
4.5 / 5
Reference : 13485
49,90 €tax incl.
41,58 € tax excl.
Shipping from France
Billing in France
Technical support in France
Bluetooth receiver to SPDIF Coaxial & Optical
CSR8675 Bluetooth 5.0 apt-X HD
Bluetooth audio aptXHD
This Bluetooth receiver allows you to connect remotely an audio source capable of emitting bluetooth with any device equiped with a S/PDIF input. Its use is easy :
  • Connect the receiver to the DAC / DSP through Coaxial or Optical output.
  • Turn all devices on.
  • Pair the audio source with the receiver.
  • Start playback.
Efficient for its price range, the receiver loads a Bluetooth chip CSR8675 supports aptX HD. This technology supports sampling rates up to 24-bit / 48kHz with a 576kbps rate. The chip automatically adapts the compression ratio to make the most of available bandwidth and to prevent loss of resolution that is not absolutely essential to meet the needs of the protocol.
The digital outputs Pulse enjoy an audio isolation transformer PE-65612 to ensure a clean and intelligible signal.
The power of the device is very easy via a micro-USB female DC 5V port. The receiver loads its own input filter to avoid unnecessarily add noise to the audio signal.
Beware, the sector and the micro-USB adapter are not provided.
bluetooh antenna
Bluetooth antenna supplied
The apparatus is provided with an imposing Bluetooth antenna.
The latter ensures accurate reception and error.
TypeBluetooth receiver
StandardBluetooth 5.0
apt-X HD
inputsBluetooth
OutputsSPDIF Coaxial
Optical SPDIF
Sampling frequency24-bit / 48 kHz
antenna length17cm
Dimensions84x70x20mm
Power supply5V-DC
micro USB port Female
Cable not included
OutputCoaxial SPDIF
OutputOptical Toslink
DAC / ADC ChipNC
Supported Bluetooth codecsAAC
Supported Bluetooth codecsSBC
11 reviews
Digitaler Eingang mit Bluetooth
Verbindung ist sehr gut und reißt nicht ab. Klang über Digitalkabel sehr gut.
This review has been posted for Bluetooth Receptor 5.0 AptX HD CSR8675 to Coaxial en Toslink SPDIF
Impec
Pas de bouton off mais super produit qui va a l'essentiel!
Très bien
Bon récepteur, signal transmis, même assez loin.
Très pratique pour éviter de changer de DAC.
Service Audiophonics toujours au top !
Parfait
Stabilité de la connexion parfaite à 11m ! Raccordé à mon "sublissime" dac Kora Hermès 2, il fait merveille... pas besoin de mettre des sommes astronomiques pour avoir une telle qualité.
hs au bout d'un an
Suite à ma critique du 12/08/19 mon modèle m'a laché à moins d'un an. Décevant.
