By buying this product you get 39 loyalty points
Récepteur Audio 4 Zones WiFi DLNA AirPlay
The Dayton Audio WFA400 is a 4-zone audio receiver, ideal for setting up a multiroom system. It is thus possible to install the WFA400 in a central point of your home and then control the entire audio system via iEast mobile application.
The iEast application turns your smartphone or tablet into a real remote control for all your compatible Dayton Audio devices. This allows you to play your favorite songs directly from a streaming service like Spotify, for example, from your network storage or enjoy the files stored on your smartphone. In addition, your music continues to play even when your phone is turned off or when you receive a call. The WFA400 is also compatible with DLNA and AirPlay technologies.
Multiroom
Play your music synchronously in different rooms in your home for smooth listening.
Multi channels
Play different songs on your different systems or groups of audio systems.
Multi users
Multiple users can control audio sources from multiple connected devices.
Flexibility
The WFA400 offers a particularly complete connectivity: WiFi 2.4GHz, WiFi, LAN, LAN, USB, RCA or optical input
Affordable
Enjoy your music anywhere in your home without having to replace your current audio system.
Convenient
Check your system remotely from your smartphone.
The installation of the WFA400 has been designed to be quick and easy. Simply download the free iEast mobile app from the Play Store for Android smartphones or from the App Store for iOS devices. Once the application is installed, it will guide you through a few steps to get the WFA400 up and running.
| Specifications | |
| Product type | 4 zones audio receiver |
| Inputs | WiFi 802.11 b/g/n 2.4GHz 150mbps Ethernet RJ45 4x Stereo RCA 4x USB-A |
| Outputs | 4x Optical Toslink 4x Stereo RCA 4x S/PDIF Coaxial |
| Frequency response | 20Hz - 20kHz +/-0.3dB |
| SNR | 83dB (A-Weight) |
| THD | 0.03% |
| Crosstalk | -81dB |
| Supported protocols | AirPlay DLNA |
| Multiroom | Yes |
| Playback control | With Dayton Audio Hi-Fly app (compatible with Android and iOS) |
| Supported file formats | MP3, WMA, WAV, FLAC, APE, ACC |
| General | |
| Supply voltage / current | 12V DC 1.5A |
| Dimensions (LxPxH) | 42.9 x 15.1 x 4.4cm |
| Housing material | Aluminium |
| Color | Black |
| Input | WiFi |
| Input | RJ45 |
| Input | RCA |
| Output | RCA |
| Output | Optical Toslink |
| Output | Coaxial SPDIF |
| DAC / ADC Chip | NC |
| Max sampling rate | NC |
| Color | Black |
| Streaming services & Network protocols | Spotify |
