AVANTREE OASIS Bluetooth 4.1 aptX Audio Transmitter and Receiver Low Latency
2.0 / 5
Reference : 11621
79,00 €tax incl.
65,83 € tax excl.
Discover the Avantree OASIS, a 2-in-1 transmitter and Bluetooth audio receiver equipped with the latest apt-X Low Latency transmission technology applicable to 2 devices simultaneously. Take advantage of high quality audio with virtually non-existent latency.
This Apt-X Bluetooth Transmitter / Receiver is ideal for wireless audio streaming from your TV, PC, laptop, iPod or other audio device analogue output(3.5mm Jack / RCA Stereo) or digital output (Optical).
Its extended connectivity, with its dual AUX Jack and Optical ports, allows its use in a multitude of cases and situations. The switch on the side of the unit allows you to easily switch between wired (Bypass) and Bluetooth mode.
Enjoy your Oasis up to 50 meters thanks to its long distance transmission and separate Class I antenna. This unit is simply powered by plugging in via its micro USB port and the supplied 5V / 500mA AC adapter.
Technical specifications:
  • Bluetooth 4.1
  • Bluetooth Profile: A2DP / AVRCP
  • Audio Codec: apt-X Low Latency / apt-X / SBC
  • Operating range: Class I / Up to 50 meters thanks to its separate antenna
  • Multipoint: Works with 2 devices connected simultaneously
  • Switch to switch betweenwired mode (Bypass) and Bluetooth mode
  • The Optical port supports sampling rates up to 48kHz
Connectivity / Packaging:
  • 2x AUX Jack 3.5mm Stereo (Input and Output)
  • 2x Optical port (Input and Output)
  • Micro USB port for power supply (5V / 500mA)
  • Dimensions: 114x75x30mm
  • Net Weight: 90g
  • Comes with: User Manual / 3.5mm Jack Cable / RCA Male to Female Cable / Optical Cable / USB Cable for Power Supply with AC Adapter
  • - Preview video of the Avantree Oasis -
    - Complete OASIS Receiver / Transmitter Bundle -
ColorWhite
livraison
reçu en temps et en heure mais manquait malheureusement l'adaptateur de courant. toujours pas utilisé donc. il semblerait que la livraison la livraison du produit manquant prenne du temps.....
This review has been posted for AVANTREE OASIS Bluetooth 4.1 aptX Audio Transmitter and Receiver Low Latency
