A la réception, j' ai été surpris par la qualité au toucher. Côté serrage, la aussi, c' est parfait. Une vraie pièce de précision !
EIZZ XLR PTFE
without Soldering
This gold-plated 3-pin XLR connector with PTFE insulation features an excellent finish with screw terminals that avoid tin soldering on the hot-spot, cold-spot and ground connectors. It is therefore ideal for designing high quality AES / EBU cables.
Its 24K gold plating, its internal PTFE insulation in the background is an excellent candidate for quality cables at reasonable cost.
Technical caracteristics![]()
| XLR EIZZ EZ206F CONNECTOR | |
| Type | XLR FEMALE |
| material conductor | Bronze Phosphorus |
| Insulated material | PTFE |
| Acceptable cable diameter | 8mm with clamping ring, 9mm without clamping ring |
| external body Material | Aluminium alloy and Chrome plated |
| Divers | |
| Length and diameter | 52.2mm / 19mm |
| Quantity | Sold per unit |
| Weight | 26g |
| Insulation material | PTFE |
| Max cable diameter (mm) | 9.0 |
| Mounting type | To weld |
| Mounting type | To screw |
| Connectic | Female |
| Contacts number | 3 |
| Connector | XLR |
| Contacts Material (Connector) | Copper Alloy |
| Contacts Plating (Connector) | Gold |
Average votes 5.0 / 5 6 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Cedric J.
daniel c.
Stephane S.
Serge V.
Jean Luc C.
