ETI KRYO Silver Plated Tellurium Copper 3 Way Female XLR Connector Ø12mm Red (Unit)
These ETI Kryo are high-end XLR female connectors designed with exceptional components. There are Tellurium Copper contacts with Silver plating for maximum conductivity and durability.
Reference : 12792
69,90 €tax incl.
58,25 € tax excl.
XLR Connector ETI KRYO
Female XLR Connector Silver Plated Tellurium Copper ⌀20x50mm Red (Unit)
ETI KRYO XLR Cuivre Tellurium Plaqué Argent
In this connector, ETI corrects a recurrent problem in many XLR connectors on the market, namely a too large mass causing a higher capacitance altering the sound. The brand also studied the question of pine thickness. From this research results that the best thickness for low voltage connectors is 0.6mm. A more or less important thickness would act negatively on the quality of restitution.
For the connector body, ETI uses Brass and Teflon dielectric insulation, this structure reduces vibration but also repels EMI / RF interference.
The connector also receives cryogenic treatment in the USA, giving it even higher performance.
Conductor materialTellurium Copper
PlatingSilver
Housing materialBrass
InsulationTeflon
Max length63mm
Max diameter20mm
Connection typeTo solder
Max cable diameterWith reducer : 8.5mm
Without reducer : 12.5mm
Package1x Female XLR connector with red ring
Insulation materialPTFE
Max cable diameter (mm)12.5
Mounting typeTo weld
ConnecticFemale
Contacts number3
ConnectorXLR
Contacts Material (Connector)Tellurium Copper
These ETI Kryo are high-end XLR female connectors designed with exceptional components. There are Tellurium Copper contacts with Silver plating for...
