Tout est a vis !
Ne pas forcer les vis sur les 3 partie
Pour le reste cela vaut le prix
Silver Plated Tellurium Copper Female 3 Poles XLR Connector Ø8.5mm (Pair)
Nexus ETI XLR connectors offer a very good design quality, integrating copper machined contacts with a small quantity of Tellurium. In addition, there is a silver plating of the contacts. This combination ensures both an excellent signal transmission and a very good contact durability. Mounting is extremely simple, the conductors of your cable can be screwed directly to the XLR connector contacts. The connector accepts cables up to 8.5mm.
| Specifications | |
| Product type | Female XLR connectors |
| Poles number | 3 |
| Conductor material | Tellurium Copper |
| Contacts plating | Silver |
| Max cable diameter | Ø8.5mm |
| Connection type | To screw |
| Quantity | Sold per pair (1 connector with red ring, 1 connector with white ring) |
| Insulation material | PU |
| Max cable diameter (mm) | 8.5 |
| Mounting type | To screw |
| Connectic | Female |
| Contacts number | 3 |
| Connector | XLR |
| Contacts Material (Connector) | Tellurium Copper |
| Contacts Plating (Connector) | Silver |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
