NEUTRIK NC3FXX-B Gold Plated 3 Way Female XLR Connector Ø8mm (Unit)
4.9 / 5
Reference : 794
6,05 €tax incl.
5,04 € tax excl.
Shipping date: 12-05-2026.
The Neutrik XX range follows the standard XLR cable connector for the X range, and offers several new features.
They are easy to assemble, with only four parts and no screws.
The contact block is made of hard plastic (polyamide) and is inserted through the back of the body.
The female contacts have a unique cage design with seven independent contact springs for low contact resistance and high integrity,
and incorporate a solder barrier to prevent the solder from flowing into the area of ​​the mating contacts.
The female connector has a larger, easier-to-handle improved solid metal latch, plus additional new spring-loaded contacts for improved body mass continuity.
Characteristics :
  • Fits on cables from 3.5 to 8.0 mm in diameter
  • Black body contacts gold plated
Insulation materialPE
Max cable diameter (mm)8.0
Mounting typeTo weld
ConnecticFemale
Contacts number3
ConnectorXLR
12 reviews
Odlični xlr konektori, kvalitetni i robusni.
This review has been posted for NEUTRIK NC3FXX-B Gold Plated 3 Way Female XLR Connector Ø8mm (Unit)
Perfect but not for 8 mm cable
Very difficult if not impossible to use on a 8mm thick cable otherwise a perfect connector.
Simple and reliable!
They are no nasty surprises with Neutrik XLRs.
The assembly is firm and tight and cable is ready for a heavy duty applications.
Les fiches "Neutrik" sont solides et parfaitement blindées. C'est parfait !
Qualité
Produit de qualité, très bien fini, parfait.
