NEUTRIK NC3MXX-EMC 3-pin Male XLR Connector Ø8mm (Unit)
The Neutrik NC3MXX-EMC is a male XLR connector that offers enhanced RF shielding for critical applications in live performance and recording, where radio transmissions or mobile phones, for example, can cause particular problems.
Reference : 21259
11,80 €tax incl.
9,83 € tax excl.
Shipping date: 01-12-2026.
Neutrik NC3MXX-EMC 3-pin Male XLR Connector Ø8mm (Unit)
NEUTRIK NC3MXX-EMC picture
The Neutrik NC3FXX-EMC is a male XLR connector that offers enhanced RF shielding for critical applications in live performance and recording, where radio transmissions or mobile phones, for example, can cause particular problems. The design ensures a continuous RF shield connection between the cable and the chassis connector housing via a circular capacitor around the cable shield. The circular capacitors act as a high-pass filter with a cutoff frequency of approximately 10 MHz.
A 24-ohm EMI suppression ferrite bead at 1 MHz between pin 1 and the cable shield provides a low-pass filter for better RF rejection.
Advantages of the Neutrik NC3MXX-EMC XLR connector:
  • Capacitive shielding integrated into the shell connection.
  • The circular capacitor around the cable shielding allows for a low-inductance connection from the shielding to the connector housing.
  • Cable shielding - Pin 1 connection includes an EMI suppression bead to block high frequencies.
  • Avoid ground loops as there is no LF shield connection to ground.
  • Rugged die-cast zinc housing, durable and resistant.
  • Mandrel-type strain relief system for secure cable clamping.
  • Cap with rubber insert provides high protection against bending stresses.
Dimensions and advantages of the NEUTRIK NC3MXX-EMC
Product typeXLR connector
GenderMale
Number of poles3
Contact materialBronze
Contact plating0.2 µm Au hard alloy over 2 µm Ni
Acceptable cable diameter3.5mm - 8mm
Cable sectionmax. 0.75mm² (20AWG)
Mounting typeContacts to weld
Locking deviceLatch lock
Nominal current per contact5A
Nominal voltage<50V
GeNEral
Overall dimensionsØ20.16 x 69mm
Package1x Neutrik NC3MXX-EMC
Insulation materialPolyurethane (PUR)
Max cable diameter (mm)8.0
Mounting typeTo weld
ConnecticMale
Contacts number3
ConnectorXLR
Contacts Material (Connector)Phosphor Bronze
NEUTRIK NC3MXX-EMC 3 Pins Male XLR Connector Ø8mm (Unit)
The Neutrik NC3MXX-EMC is a male XLR connector that offers enhanced RF shielding for critical applications in live performance...
