Connector
Max cable diameter (mm)
Connectic
Contacts Material (Connector)
Contacts Plating (Connector)
Contacts number
3 - 5
Mounting type
Max panel thickness
mm
mm
Roland S.
Dac tv
Walter V.
Great product!
Joli mais non..
XLR Sockets
Discover our range of XLR plugs, for the integration of an XLR connector in your HiFi equipment or on your audio modules.
