NEUTRIK NC3MAH Male XLR Plug Gold Plated for PCB
The Neutrik NC3MAH is a 3-pole XLR socket with gold-plated contacts and separate ground pin. It allows easy mounting on PCBs.
Reference : 725
1,30 €tax incl.
1,08 € tax excl.
Shipping date: 24-09-2026.
Neutrik NC3MAH
Neutrik NC3MAH Embase XLR Mâle Plaqué Or pour PCB
Product typeMale XLR plug
Mounting typeTo solder
Lifetime> 1000 cycles
Contacts materialCopper alloy
Shell materialPolyamide
Temperature range-30°C / +80°C
StandardsUL 94 V-0
IEC 61076-2-103
IP40
IEC 68-2-20
Capacitance between contacts≤4pF
Contacts resistance≤6mΩ
Dielectric strength1.5kVdc
Insulation resistance> 10GΩ
Rated current per contact6A
Rated voltage< 50V
Insertion / withdrawal strength≤ 20N
Max cable diameter (mm)N/A
Mounting typeTo weld
ConnecticMale
Contacts number3
Max panel thickness (mm)N/A
ConnectorXLR
