Pierre Marie S.
AVIS SUR QUALITÉ ET MONTAGE
Rien à dire sur la qualité des matériaux et l’usinage. La plaque inférieure du boîtier aurait pu être un peu plus...
Gregory O.
Not copper
Waste of money. No copper anywhere on this plug as I filed it down and no copper.
Guillaume D.
Oubliez tous les autres
Ayant récemment acquis une paire de Chario Aviator Nobile, j'étais à la recherche d'électroniques à la hauteur de...
Avis clients - Il y a 21046 avis.
WOONG KYU J.
AUDIOPHONICS OPA1612 AOP Double DIP8 (Unité) L'amplificateur opérationnel Audiophonics OPA1612 se base sur une authentique puce 1612 de Texas Instruments. Cet AOP permet une très bonne performance...
OPA1612 GOOD !!!
Replacing the LME49720 with the OPA1612...
From fast transitions and crispness to solid bass...
It is a truly excellent product that allows you to clearly hear even sounds you previously missed.
When I opened the box and saw the product, I could feel confident in its quality,
and listening to the sound, I feel a sense of happiness.
Peter H.
ELFIDELITY AXF-107 Filtre d'Alimentation PCI Express / PCI Express 16x Le module AXF-107 de Elfidelity est un filtre d'alimentation à découpage pour ordinateur se raccordant en PCI Express ou PCI Express 16x et destiné à offrir un courant plus...
Noticeable positive effect on the sound
Like one of the other reviewers, I'm using this power filter together with a Matrix Element H USB card. The reason I bought this filter is because I read that the Element H uses motherboard power for its internal electronics and the on-board clock. The external power input only provides power for the USB port. This made me suspect that there was a lot of untapped potential in the Element H if you gave it cleaner power from the motherboard itself. Judging by what I'm hearing, that assumption was correct. The computer is a gaming PC, using a Asus Rog Strix B650E-F motherboard with Ryzen 7600X a Radeon 7800 XT Graphics card.
I placed the power filter one port above the Matrix Element H as recommended by other reviewers. The effect is a more detailed sound, both in surface texture of instruments like strings, but also improved separation in busy parts. The dynamic punch is also clearly better. The difference is obvious and appreciated. Given the price of this power filter, I think this is a cost effective solution. If you're serious enough about sound that you're using a separate USB card, I think this Elfidelity AXF-107 filter is highly recommended. You will most likely also hear an improvement.
Jürgen L.
ATAUDIO Q8RF Connecteurs RCA Femelle Ø7.5mm (La paire) Ces connecteurs RCA plaqués or sont conçus pour assurer une bonne conductivité et résister à l'oxydation. Les contacts sont faits d'alliage de...
The product description is incorrect — these are not copper‑core connectors
These Female RCA Connectors are not gold‑plated copper contacts. I removed the galvanic gold layer, and underneath it’s the usual brass you find in low‑cost connectors. And the strain‑relief bar is magnetic.
Unfortunately, the product description is wrong. It Would be great if the description could be updated to match the actual materials.
claude B.
FIIO SR11 Lecteur Réseau WiFi Airplay Roon Ready 32bit 768kHz DSD256 Argent Le lecteur réseau SR11 de la marque FiiO est un petit lecteur réseau, compact et performant, conçu pour s'associer avec le DAC/amplificateur casque K11. Il...
excellent petit steamer
bonjour, je suis ravi du rendu sonore en écoute via rca numérique.
Mais aucun son par les sorties usb
et je ne comprends pas pourquoi
c'est un gros inconvénient .
Jean-Pierre B.
VIABLUE HS SPIKES BLACK Pointes de Découplage Noir (Set x4) Les pointes de découplage Viablue HS Spikes permettent de limiter les vibrations allant de vos enceintes ou appareils vers les surfaces inférieures. Elles...
Beau produit
Il manque un mode d’emploi.
Il faut fixer le socle en premier : tête de vis M6 à l’intérieur (tête en bas) en choisissant une longueur adaptée.
On boulonne par en haut.
On visse la pointe sur le socle ainsi posé.
C’est très beau très bien fabriqué et très cher. Mais bon quand on aime on ne compte pas.
Kostadin K.
FOSI AUDIO ZP3 Préamplificateur symétrique NE5532 Le Fosi Audio ZP3 est un préamplificateur symétrique se basant sur des AOP NE5532. Il offre une qualité de restitution sonore dénuée...
FOSI AUDIO ZP3
A wonderful preamplifier, I listen to it in bypass mode, it sounds more bassy to me. I give it 4 stars because it arrived with a defective power cable. The side of the IEC C5 "Mickey Mouse" connector is bent and very loose, I had to buy a new one.
bernard g.
cablage xlr
cable a 9 fils pour relié les connecteur plaqué platine section 1.05mm2 cable audiophonics neotech en cuivre pour la masse et en argent trés pur houla le resultat le tout acheté chez audiophonics
bernard g.
NEOTECH SOCT-20 Fil de câblage Cuivre UP-OCC PTFE 0.5mm² Neotech a longtemps été le leader dans la production de câbles en utilisant le cuivre UP-OCC "monocristal" développé par le professeur Ohno de...
cablage xlr
bonjour a tous j ai acheté ce fils pour fabriqué un cable xlr haut de gamme cable cuivre pour la masse cable argent pour le point chaud et froid resultat apres 100 heures de rodage le son est trés realiste avec basses amples et aigus d une grandes finesse
beaucoup de détails qui je n avais pas avant avec un naturel dans les instruments impressionnants le cable est tréssé par 3 fils par points 9 fils pour cabler chaques xlr 1mm2 par points malgré le prix elevé des cable argent le resultat est a la hauteur des moyens mis en oeuvre les connecteurs sont a la hauteur du reste en attendant des connecteur argent 7n le tout acheté sur audiophonique
Carlos N.
BURSON AUDIO V7 VIVID PRO AOP Simple (La paire) Évolution du V6 VIVID, le V7 VIVID Pro se distingue par sa clarté, sa précision et sa dynamique élevée. Il...
Dynamique et neutre
On paye le prix mais niveau qualité ils sont top ces AOP Burson Audio tant sur la dynamique, la 3D, la texture. Je les ai monté sur un ampli de puissance sur l'étage d'entrée XLR et RCA et ils sont hyper silencieux.
Gregory F.
LUXSIN X8 DAC Amplificateur Casque Préamplificateur DSP WiFi Bluetooth 5.1 8x CS43198 32bit 768kHz DSD512 Le Luxsin X8 est une solution audio tout-en-un haut de gamme pensée pour les audiophiles exigeants, remplissant les fonctions de DAC, amplificateur casque et...
Très bonne machine
J'avais eu l'eversolo z8, je l'avais trouvé très bien mais là sortie casque n'était pas assez puissante.
Là on a un peu la même machine mais avec une sortie casque très puissante, et en plus l'accès au peq et à des bases de données.
J'avais récupéré un pdf oratory pour he1000 v2, je trouvais le son mauvais, j'ai cherché et j'ai failli tout renvoyer.
J'ai testé les courbes de la base de données via le peq luxsin, j'ai pris une Harman 2013, baissé un peu le grave, monté un peu le high shelf aigu et tout est rentré dans l'ordre. L'eq oratory que j'avais bouffait trop de medium donc le son était nasillard.
Maintenant j'écoute sans plus me poser de question.
Vraiment une très belle machine, eversolo est pour moi une des meilleures marques chinoises.
Ivan B.
Fantastic upgrade for my system!
I bought the ELECAUDIO HP-25OCC (2x5.1mm²) cables to complete my audio setup (a high-end DAC with discrete op-amps, a vintage heavyweight Sony ES amplifier, and KEF 105/3 speakers). The result completely exceeded my expectations! Right after connecting them, the soundstage cleared up remarkably, becoming much more focused and three-dimensional. At the same time, the overall sound gained a beautiful, natural density and body. The bass is tight and authoritative, while the mid-range sounds incredibly lifelike.
I also want to highlight the Audiophonics team. Extremely correct, with very fast reactions and a highly professional attitude from the moment I placed the order to the actual delivery.
Highly recommended – both this excellent OCC cable and the store itself!
Ramaccini G.
TOPPING PROFESSIONAL E8X8 PRE Interface Audio USB 8 Entrées 8 Sorties 24bit 96kHz L'interface audio E8x8 PRE de la marque Topping Professional est un appareil de haute qualité conçu pour répondre aux besoins des musiciens et des...
Interfaccia superba
Silenziosissima,qualità sonora elevata.
Carsten R.
AUDIOPHONICS AP300-M450ET Amplificateur de Puissance Class D Mono Purifi 1ET6525SA 1x450W 4 Ohm Nous sommes fiers de vous proposer le Audiophonics AP300-M450ET, un amplificateur de puissance mono Class D basé sur un module Purifi 1ET6525SA. Cette version...
i forgot to rate
should be 5 stars
Carsten R.
No love at first feel
I did not like the sound at the beginning.
Hi Input and hi gain setting together made everything so distorted the amp switched off sometimes.
It startet to sing after i avoided the single ended input and replaced the opamp with a discreet one.
Now i am very pleased with the sound.
Build quality is excellent.
Sahin T.
AUDALYTIC DR70 DAC R2R Lecteur Réseau Roon AirPlay UPnP Bluetooth 5.0 32bit 768kHz DSD512 Noir Le Audalytic DR70 est un DAC réseau haut de gamme conçu pour les audiophiles exigeants, alliant une architecture R2R discrète, une connectivité...
Excellent mais bug logiciel
Magnifique dac qui offre une spatialisation exceptionnelle, un détail et précision grandiose. Par contre bug logiciel, le Bluetooth n'est plus détecté après une certaine période sans l'utiliser, il faut débrancher la prise courant et relancer l'appareil
Gilles F.
Connecteurs RCA Plaqué Or Ø8mm (La paire) Gris Ces connecteurs RCA de belle qualité profitent de contacts plaqués or, assurant une bonne conductivité électrique et résistance à...
Apparemment tres bon
J'ai fait le test avec un aimant... La partie connecteur n'est pas ferreuse, la partie qui se soude au cable est ferreuse...
Tube isolant fourni. Ouverture de 8mm qui le fallait pour le cable. RAS bon prix. J'ai du ouvrir ce qui se connecte à la masse car il est trop fermé pour les 8mm (6-7 sans la gaine) du cable. Apres on resserre.
Ne vous plantez pas en mettant les éléments avant de souder quand c'est déjà fait de l'autre cotré...
Très bien !
Peu coûteuse et efficace, tout métal, elle est facile à souder.
Accepte du câble jusqu'à 8,5mm de diamètre.
Bravo !
J'adore ce câble de modulation !
J'ai déjà utilisé 2 paires de 1,50 mètre (6 mètres commandés) sur play/record de ma platine cassettes Marantz Sd6020 HDG avec une très grande satisfaction. Son transparent, neutre, bande passante étendue, aucun bruit parasite, le triple blindage est efficace.
Après essai de ce câble 75 ohms entre mon convertisseur et mon ampli intégré à tubes, j'ai été convaincu à nouveau du résultat sonore. Pour ce montage, 4 fiches RCA Viablue 8mm sans soudure.
Je viens de commander 9 mètres supplémentaires pour réaliser encore 2 paires en 1,50 mètre et 2 paires en 0,75 mètre pour mon beau tuner, mon ampli casque pro etc, etc.
Montage facile avec fiches RCA Amphenol peu coûteuses (sans le manchon).
Les 2 tresses internes sont soudées ensemble du côté source pour la masse et seule la tresse en cuivre est soudée de l'autre côté.
La neutralité est garantie, mieux que mes câbles de marques que j'ai désormais revendus.
Livraison Audiophonics très rapide.
Merci de proposer de si bons produits !
Michael S.
AUDIOPHONICS EVO-SABRE DAC Symétrique 2x ES9038Q2M USB GPIO Raspberry Pi SPDIF Bluetooth XLR RCA Successeur direct de notre fameux module DAC I-Sabre ES9038Q2M, le EVO-Sabre DAC 2x9038Q2M est une version symétrique du convertisseur avec une panoplie complète...
The Sound is good the Stage is deep and Wide with an Alternative OPA like Oracle II is it much better
Alexandre p.
LUDIC AESIR Câble Optique Toslink Fibre de Verre 1m Le Aesir de Ludic Audio est un câble Optique Toslink hautes performances. Il profite d'une belle conception avec une fibre en verre assurant une transmission stable, sans...
Intégrité de la source réduction du jitter
Utiliser sur deux parfums différents: SMSL(akm) et Audio-gd(wm8741) pour le casque.
L'étage en terme de gain est tout simplement époustouflant.
C'est bien réel, la séparation des instruments est vraiment distincte. Le spectre supérieur est ultra détaillé. Spatialisation augmenté. Je ne reconnais pas certains Kickdrums par exemple.
Il ne me reste plus qu'à fabriquer de nouveaux cables pour mes monitors.
Sékou K.
RAMM AUDIO ZEUS SI 15 Câble Secteur Schuko C15 Cuivre OCC Triple Blindage 1.5m Ramm Audio propose avec le Zeus SI 15 un câble d'alimentation audiophile de très grande qualité. Profitant d'une conception exceptionnelle, il intègre...
Câbles remarquables.
Branchés sur mon Drive CD Atoll 400 SE, les détails et la précision des timbres sont remarquables. Câbles étonnants, à brancher judicieusement sur l'appareil ad hoc.
Marcel D.
Was für ein Upgrade!
Ich nutze einen Aiyima A80 mit einem WiiM Pro Streamer und ELAC Uni-Fi Reference UBR62 Lautsprechern in meiner Stereokette in einem 24 m² großen Zimmer. Nach langer Recherche im Internet wollte ich mein Setup etwas aufwerten. Ich war anfangs etwas skeptisch, doch die schnelle Lieferung und die unkomplizierte Bestellung eines originalen Sparkos-Op-Amps bei Audiophonics.fr war – selbst für den Versand aus Frankreich nach Deutschland – absolut erstaunlich. Der Tipp, dort zu bestellen, kam übrigens von Gemini.
Kurzum: Ich habe den Aiyima A80 aufgeschraubt, den Op-Amp im vorhandenen Steckplatz einfach ausgetauscht und das Gerät wieder zusammengeschraubt. Was sich meinen Ohren dann präsentierte, war schlichtweg umwerfend. Der ohnehin schon gute Klang des Aiyima wurde noch einmal getoppt: Präzision, der Punch des Basses, die Detailtiefe und die Bühne haben sich maßgeblich verbessert. Gemessen an den moderaten Kosten für den Op-Amp ist der klangliche Zugewinn phänomenal – ein besseres Preis-Leistungs-Verhältnis lässt sich kaum erzielen.
Eine absolute Kaufempfehlung und ein Daumen hoch für diesen Shop, bei dem von der Bestellung bis zum Erhalt des Pakets alles zu meiner vollsten Zufriedenheit geklappt hat.
Wojciech S.
PSVANE EL34-Z Tubes de Puissance Pentode (Quad Appairé) Le tube de puissance EL34-Z de PSVane propose un son chaud et doux, ample et naturel, un bel équilibre et un bruit de fond absent. PSVane nous offre ici un tube à...
Warm sound of tubes
These tubes offer a warm and soft sound, a well-filled midrange, and good value for money. Highly recommended! Very good contact with audiophonics.fr !!!
Igor B.
Great amplifier
For the price, I can't find any real downsides. It sounds phenomenal, looks okay and works without creating almost any heat. My only nitpick is that it is too light, so when I push the button I push the complete amp inward. Overall - highly recommended.
Christophe T.
Dégraisse bien le signal, incontestablement
Transitoires plus marquées, graves nettoyés, aigus plus soyeux, la changement est évident sur la sortie de box. Essayé en réception connecté à l'entrée de streamer la différence n'est plus qu'à peine perceptible mais encore là. Je l'avais pris pour essayer, par curiosité vu le prix et après essai, n'ai pas pu le retirer et revenir au branchement direct semblant un peu mou et sale une fois habitué à l'apport de ce petit isolateur galvanique.
Christophe T.
Sur un système large bande, retire le voile gris des cables cuivres, comme si vous aviez nettoyé la vitre de votre fenêtre sur son...
Christophe T.
VIBORG LAN8 Câble Ethernet RJ45 Cat8 Argent Pur Traitement Cryo 1.5m Le câble Ethernet RJ45 Viborg LAN8 est un câble Ethernet haut de gamme profitant d'une conception exceptionnelle. En effet, ce câble se dote de conducteurs en...
Très large, médium crépitant mais chaud et aigu hyper-soyeux :-o
Installé derrière une box et un isolateur galvanique (iFilter). La connexion source-preampli-ampli est déjà en neotech (argent pur).
La différence de restitution est évidente dès la connexion. L'excellent cable Ethernet cuivre-argent installé avant produisait déjà un son bien solide, pêchu, parfaitement défini et propre, plein et doux. Avec ce viborg, l'impression de retirer un filtre physiologique est déroutante la première heure. Le médium crache une tonalité générale soyeuse sur tout l'aigu (sans distorsion) comme un bruit rose, crépitante sur les voix parlées (radio) et très aérée sur les basses dont la tonalité s'éclaircit en semblant recentrée vers l'infra, Après une journée, reprise du cable cuivre argent et comparaison, l'impression de bruit rose du viborg est atténuée et laisse place à celle d'une réponse en fréquence très linéaire/plate, faisant penser que le cuivre-argent pourrait encore atténuer le médium selon les standards usuels de confort d'écoute, bien que déjà très aéré, clair et complet en comparaison de cuivre standard faisant sourdine. La partie médium-aigue du Viborg coule comme l'eau d'un ruisseau dans les oreilles, définitivement plus présente, jusque dans les graves de fait moins prépondérants, mais clairs et lourds comme du verre blindé? Ce câble ne devrait pas donc convenir à un système de petit volume et puissance, susceptible dans ce cas de rendre l'écoute diaphane et très/trop articulée, manquant de chair, voire douloureuse. Au contraire, sur une installation de dimensions généreuses (Martin audio, Magnepan, Audio research, Krell et autres Pass Lab), l'air qu'il apporte sur tout le spectre, avec les transitoires exceptionnelles sur le médium et la libération d'un soyeux d'une rare douceur sur le haut-medium et l'aigu raviront les oreilles sur tous les enregistrements, de prises des années 60 aux énormes atmosphères de Boris Blank à l'institut Franhofer... Un câble de très haut niveau, très linéaire, sans filtre ni correction, mais qui ne pourra pas convenir pas à tout les systèmes ou toutes les oreilles. Ne conviendra pas sur les systèmes manquant de basses mais jubilatoire sur ceux en disposant généreusement.
Franck B.
Très qualitatif!
La façade avant en 10mm eloxée est vraiment de belle facture.
Par contre oui une notice de montage serait la bienvenue étant donné la quantité de vis qui est fournie. Toutes ne servent pas.
Sinon ravi, je vais pouvoir me faire une jolie multiprises 8 ports.
Dommage aussi d'imposer l'emplacement de l'embase IEC.
jean-Claude D.
ELECTRO HARMONIX 6CA7EH Tubes Tetrode d'Amplification (Quad Appairé) Les tubes d'amplification Electro Harmonix 6CA7 sont des tetrodes classiques au format  Big Bottle . Ils sont construits pour s'adapter aux amplificateurs disposant d'un...
Line magnetic lm 211ia
Possédant cet ampli depuis 4 ans j'hésitais constamment entre les modes triode et ultra linéaire avec les lampes d'origine ( shuguan ) et des jj mises il y a deux ans.
Le remplacement des el34 par des 6ca7 il y a deux mois et des psvane pour les lampes de pré ampli m'ont convaincu : j'ai oublié le mode UL, en mode triode puissance et détails sont au rdv
A essayer !!!
Victor C.
AUDIO-GD HE-1 MK3 Préamplificateur Class-A Symétrique ACSS XLR RCA Argent Audio-GD nous présente une fois de plus la quintessence de la technologie en matière d'audio avec les produits de la série HE (Ici le HE-1 MK3),...
Bonjour à tous ,
Je viens de recevoir mon préampli Audio gd
Magnifique pièce
Ils n’ont pas menti sur le site
Mihai Claudiu R.
AUDIOPHONICS MPA-S250NCX RCA Amplificateur de Puissance Class D Stéréo NcoreX NCx252MP 2x250W 4 Ohm Le Audiophonics MPA-S250NCX RCA est un amplificateur stéréo basé sur un module d'amplification Hypex Ncore NCx252MP. Cette solution est idéale pour...
My EndGame amp
Salut, am cumparat acest amplificator dintr'un impuls de moment de pe OLX. Stiam despre modulele Hypex dar am ezitat achizitia.
Dupa aproape o luna de la achizitie pot sa spun urmatoarele:
Constructia este robusta, cutia aparatului arata bine, materiale si comectica de calitate.
Prin dimensiuni poate fi pozitionat si vertical ocupind foarte putin loc.
Cuplat la iesirea unui WIIM Ultra produce un sunet dinamic, echilibrat si foarte detaliat. Puterea este pe masura.
Boxele pe care le'am ascultat pe aceast setup sunt Monitor Audio Bronze 100 si Monitor Audio Silver 100 7G. Pot sa spun ca MPA250ncx la aduce la "viata", sunetul produs s'a transformat major fata de Denon PMA30 sau chiar WIIM AMP Ultra. Se simte imediat un control mai bun al boxelor si un sunet mai "aerist" si mai bine conturat.
Cu boxele Focal Theva No.1 si Heco Aurora 300, aflate in dotare, practic se obtine cel mai bun sunet pe care aceste boxe il poate produce. Toate boxele suna mai bine acum.
Cu acest amp se poate diferentia clar caracterul fiecarui set de boxe. Super!
Conexiunea dintre WIIM Ultra si MPA-S250ncx am facut'o cu cablu Sommer Cable Spirit LLX (0,8m) iar de la MPA-S250ncx la boxe cu Sommer Cable Orbit 225 MK2(2,5m), cu rezultate foarte bune .
Totusi utilizand si alte cabluri RCA-RCA de interconexiune intre WIIM Ultra si MPA-S250ncx pe canalul din dreapta, in repaus, se aude un foarte usor riplu, abea sesizabil dar se aude.
Ramane sa depistez de unde apare acest riplu.
Datorita sunetului excelent, performantelor superioare si pretului accesibil recomand acest amplificator.
jean michel G.
Fonctionne apparemment
J'avais un déséquilibre avec mon preampli très désagréable à très bas volume. Souci apparemment disparu avec ces attenuateurs réglés à-10db.
christian b.
AUDIOPHONICS Sélecteur de Source RCA 4 vers 1 Réversible Ce sélecteur de source RCA Audiophonics permet de relier différentes sources analogiques sur un amplificateur, un préamplificateur ou des...
COMMUTAYEUR AUDIOPHONICS
je suis totalement satisfait du commutateur de fabrication audiophonics - réponses très rapides pour les demandes de renseignements concernant mon besoin - également expédition et livraison très rapides;
leurs fabrications de cables à la demande sont également de très haute qualité
je recommande sans hésitation audiophonics pour la qualité de leurs services et de leurs fabrications
Dario S.
OYAIDE ACROSS 3000 Câble Haut-Parleur Cuivre 102SSC 2x2.8mm² Ø9.2mm Le câble Oyaide Across 3000 est maintenant disponible au mètre. Profitez de l'occasion pour améliorer vos installations audio personnalisées avec ces...
Ottimo cavo
Ho fatto diversi ordini in questo sito, arrivati sempre in tempo breve, tutto ok, mai uno sbaglio.
Parlando del cavo, l' Across 3000 ancora in rodaggio ha scalzato il QED Golden anniversary xt che avevo in uso.
Avevo provato:
Supra Classic 1.6
Supra Classic 2.5
Thender 52-100
Connection integrated Solution S212.2
Connection integrated Solution S214.2
QED XT25
Oyaide Explorer V2 102 SSC
Furutech FS 502
Neotech Nemos 3080
QED Golden Anniversary xt
Ho preferito a tutti il QED Golden,
stavolta invece l'ultimo arrivato, l' Oyaide Across 3000,
l'ho preferito senza ripensamenti, scena più larga e profonda, fluido, timbrica migliorata, esteso e aperto agli estremi banda senza essere fastidioso.
Lo consiglio.
Dennis H.
SMSL DO400 DAC ES9039MSPRO Amplificateur Casque XMOS XU316 Bluetooth 5.1 LDAC 32bit 768kHz DSD512 MQA-CD Noir SMSL dévoile avec le DO400 un DAC / Amplificateur casque puissant et qualitatif. Il intègre des composants de qualité tels que la...
The best DAC/Headphone amplifer for 500€
This DAC and headphone amplifier sounds very neutral, a good clean sounding device.
Thierry V.
NEOTECH NES-5002 Câble Haut-Parleur Cuivre UP-OFC 2x2mm² Ø9.5mm La gamme NES-5000 de Neotech est composée de câbles à conducteurs Cuivre Ultra Pur UP-OFC tout en assurant un prix abordable. Le NES-5002 intègre 2...
Plus qu'étonnant!
En remplacement d un elecaudio que j offre a mon fils...je n en attendait pas gd chose, et bien quelle surprise!! Surtout au prix. Il me parait plus equlibré que l elecaudio qui chez moi favorisait le medium ,bas medium. La lumière revient dans le haut sans aucune agressivité, gain en transparence, medium parfait , grave tres tenu, scène ok...je ne vois pas ce qu on peut avoir de plus a ce prix...j'ai des cables thdg(2ke) sur un autre système..je peux jauger du RQPperformance de ces neotech...ils m ont franchement impressionné!
Recommandés à 100%
Michel R.
Acheté pour mon NUC Roon afin de tenter d'améliorer le résultat sonore : l'image s'est élargie, la dynamique s'améliore un peu, le grave est plus tendu le médium et l'aigu gagnent en présence en l'absence de toute dureté. Je suis donc pleinement satisfait de mon achat.
Je regrette toutefois que la diode rouge soit si violente et que l'option façade noire ne soit pas proposée (cela fait tache au milieu de mon système.)
Mais l'amélioration est là pour un prix qui reste assez raisonnable.
Daniel F.
LHY AUDIO AS6 Switch Réseau 5x RJ45 1x Fibre Optique Argent Avec le AS6, LHY Audio nous propose un switch réseau, évolution du modèle SW6-SFP, comprenant 5 ports RJ45 dont un profitant d’une isolation...
Muy eficaz
Muy eficaz
CATALIN L.
SILKLINE ZUKI III DAC Symétrique 2x AD1955 XMOS XU208 32bit 192kHz Noir Le Silkline Zuki III est un DAC symétrique reposant sur un combo de deux puces de conversion numérique-analogique Analog Device AD1955 ainsi qu'une interface USB...
This is a very interesting DAC that goes against the current trend.
The first thing that stands out is the sense of solidity and scale. The sound is full, grounded and direct, with a strong and stable foundation. It doesn’t feel processed or “digital” in the modern sense — it reminds me more of the way good CD players used to present music: coherent, immediate and natural.
What impressed me most is the way it reproduces the inner life of sounds. Instruments don’t just have outline and detail, they have vibration and texture. For example, accordion or piano sounds very realistic, with a convincing sense of energy and movement inside the note.
Transparency is also very good, but not in a forced or analytical way. Details are present and easy to follow, yet nothing is pushed forward artificially. There is no glare or harshness, just a very natural flow that makes it easy to hear into the recording.
The DAC has excellent PRaT — rhythm and timing feel right, music flows effortlessly and keeps you engaged. It’s not about spectacular detail, but about coherence, which in the end reveals more.
Compared to many modern DACs, this one sounds less dry and less “technical”, and much more musically convincing. It invites you to listen to music rather than analyze it.
Overall, a very simple DAC, but a musical and surprisingly capable one, especially if you value realism, coherence and emotional involvement over pure technical performance.
I would also like to thank the person or team behind this DAC. It really feels like they put soul into it, not just technical effort. You can hear that it was designed by people who care about music, not only measurements.
Léo S.
Très bon ampli qui vient remplacer un vieux dinosaure Akai et me fait redécouvrir ma paire de Borea BR04, couplé à un Wiim Ultra. Les basses sont précises et claires, les autres fréquences sont bien à leur place. Du bonheur. Je reprocherai juste la forme tout en longueur de l’ampli, pas forcément simple à placer. Expédition rapide et envoi soigné.
Michael L.
CANARE 4S6G STARD QUAD Câble Haut-parleur Cuivre OFC 4x0.5mm² Ø6.4mm Voici le câble CANARE 4S6G, un câble Haut-parleur parfait pour un bi-câblage de qualité et à petit prix. Ce dernier possède 4 conducteurs en Cuivre OFC haute qualité.
Thin versitale cable for a low price
I wanted canare ofc cable, canare 4S11G was to expensive so the only audiophonics canare option is 4S6G
Normal fast delivery less than a 4 days
Easy to strip. (no bi wiring so 17 awg instead of 20 awg)
Sound out of the box more neutral than qed xt25.
Less bright and bass heavy
My speakers go down to 4 ohm maby 3.7ohm and i have up to 2x200 watt in 4 ohm.
Something thin for a not to big amp,speaker you can hide (if black isn't a problem) or just wanna try bi wiring with a mini system, canare 4S6G is not a bad option
Im only giving it 4 start since audiophonics failed to respond to my request to get a thicker cable than the canare 4S6G before they sent the cable
Thierry V.
DOUK AUDIO A5 PRO Amplificateur Intégré Class D PFFB TPA3255 NE5532 Bluetooth 5.1 2x120W 4 Ohm Le Douk Audio A5 Pro, version améliorée du A5, est un amplificateur intégré compact et esthétiquement singulier, conçu avec des...
Etonnant!
Je possede 3 amplis dont un thdg...ce douk, acheté pour offrir à mon fils m'a franchement étonné surtout à son prix..c est bien timbré, dynamique, belle construction, ne chauffe pas tant qu'annoncé...a mon avis concurrence facilement des amplis jusqu'à 800-1000e...les reproches: 1 seule entrée et pas de telco..mais bon vu le prix
Habitué à du relativement hdg , je reste surpris
Yves C.
TOPPING E50 II DAC AK4497S XMOS XU316 Bluetooth LDAC 32bit 768kHz DSD512 Noir Le Topping E50 II, évolution du E50, est un DAC qui offre d'excellentes performances grâce à un choix de composants méticuleux. Il présente...
Musicalité
J'utilisais le E30 ll Litle que je trouvais déjà très bon. Le E50 ll par rapport au E30 ll Litle donne une impression d'un son moins analytique, mais plus musical et plus spatial
RENE R.
1877 PHONO THE SPIRIT
COMME TOUJOURS AVEC CETTE MARQUE LE RAPPORT-QUALITE PRIX EST EXCELLENT.
Mike V.
OYAIDE HSR-AG 5N Fils Argent 5N Plaqué Rhodium pour Porte-Cellule (x4) Les fils pour câblage de cellule Oyaide HSR-AG profitent d'une magnifique conception, avec des conducteurs en Argent 5N pur. Ceux-ci sont fabriqués à l'aide...
Excellent upgrade over stock wires
Great upgrade from stock wires. Definitely recommended.
RENE R.
1877PHONO CryoLitz-Ag Fils de Litz Pur Argent 40mm (x4) 1.0 - 1.2 Un set de fils de liaison (Headshell Leads) grande qualité pour cabler la cellule d'un lecteur vinyle.
1877PHONO CRYOLITZ-AG
excellents fils de liaisons, excellente marque pour ne pas dire plus.
chaque fois que j'achète des produits de cette marque j'estime que j'ai ce qu'il est possible d'avoir de mieux!
Steve S.
Le SU-1DAC est incroyable, mon système modeste devient audiophile.
J’ai déniché pour 20 € un ancien lecteur DVD Sony, en excellent état, avec un vrai charme vintage des années 2000 et une construction robuste. Pas de HDMI, mais des sorties optique et coaxiale, ce qui en fait une base parfaite. Je l’ai donc reconverti en lecteur CD dédié, associé à un DAC SU-1, le tout alimenté par un ampli Marantz.
Résultat : une véritable claque. Mes oreilles n’en revenaient pas. J’ai redécouvert toute ma collection de CD : les instruments sont parfaitement détachés, les voix naturelles, avec une présence presque “live”. Aucune dureté ni coloration numérique, tout reste fluide et précis. Même les basses, sans caisson, sont étonnamment profondes et bien tenues sur de petites enceintes bibliothèque Mission.
Je viens du monde audiophile et j’ai écouté (et possédé) des systèmes valant plusieurs dizaines de milliers d’euros. Et pourtant, à ce prix-là, avec ce DAC intégré à ma chaîne, le résultat est tout simplement bluffant — un véritable petit miracle musical.
Note : 9/10.
Emmanuel A.
Idéal sur un dac
Des Cables, que je préfère sur les différents DAC mis à ma disposition, ce modèle est parfait
J’ai pu le tester aussi normalement sur SAcd et le lecteur réseau le rendu est toujours aussi. Bon il fait égal avec des modèles que j’avais payé plus de 1000 €.
Emmanuel A.
CANARE L-5CFB Câble coaxial 75 Ohm blindé Haute performance Ø7.7mm Câble conçu et fabriqué au Japon par la célèbre firme CANARE, ce câble coaxial 75 Ohm L-5CFB de très haute qualité était originellement dédié au marché professionnel du broadcast.
Meilleur cable sub
L’un des meilleurs, Cable, subwoofer qu’il m’a été donné d’essayer, il a détrôné sans forcer des Cable de 20 fois son prix
Je mets sur mes deux caissons
Gabin D.
FURUTECH FT-818 (R) Borniers Cuivre pur plaqué Rhodium (La paire) Les borniers Furutech ont été développés dans l'optique de satisfaire les consommateurs les plus exigeants.  Ils sont fabriqués au...
Incroyable
Borniers juste incroyable merci Furutech toujours les bosse dans leur domaine ces borniers amène vraiment un filtre en plus à l’installation hi-fi
