The latest 10.32 reference in the family of Audio-GD family integrates the new USB interface of the brand (Amanero).
This new product also offers Upsampling up to 8X thanks to its built-in DSP1, its volume controller based on 4-channel digital relays is an example of transparency.
This unit combines the functions of preamplifier DAC and headphone amplifier is delivered with its dedicated remote control.
Son Modern DAC allows you to manage 24bit 192Khz sources directly via USB and 24bit 96kHz via SPDIF.
The 100% discrete design of this preamplifier is backed by a group of 8 dedicated Class A power supplies.
24k Gold Plated RCAs and Nover (UK) capacitors have been specially manufactured on Audio-Gd specifications.
| Signal / noise ratio |
| Gain | +7 DB (volume control at 70 steps) (XLR) |
| USB Interface | VT1731 (USB32) |
| converters | 4 X PCM1704UK |
| Headphone output power capacity | 6000MW / 50 ohms 3500MW / 100 ohms 1200MW / 300 ohm 600MW / 600 ohms |
| Volume characteristics |
| Output impedance | 1 ohm / Headphone output |
| Output Levels | Headphone Output: 19V RMS |
| Input sensitivity |
| Frequency Response | 20Hz -20KHz (<- 0.1DB) |
| Dimensions | 430 x 430 x 93 mm |
| Weight | 15KG |
| Accessories | AC power cord X1 USB cable X1 |
</ P>
</ P>
</ P>
</ P>
</ P>
| Input | XLR |
| Input | Optical |
| Input | RCA |
| Input | SPDIF |
| Input | BNC |
| Input | USB |
| Output | RCA |
| Output | ACSS |
| Output | XLR |
| Color | Black |
