Audio-GD NFB-3 (2015) ES9018 DAC DSD / DXD 32Bit / 384KHz USB32
Reference : 8505
579,00 €tax incl.
482,50 € tax excl.
The NFB-3 (2015), the newest non-feeedback digital analog converter, incorporates the brand new USB interface (USB32) and a new low-noise R-Core transformer.
This new product also has different filters at the output of the converter.
NFB is the acronym for Non-feedback; technology used by Audio-Gd so as not to "color" the sound at the level of the electronics of the output stage giving you a sound of a very professional neutrality.
Its state-of-the-art VIA VT 1731 interface allows you to manage 32-bit 384kHz sources directly via USB.
The 100% discreet design of this converter is backed by a high power (Class A) power supply.
The 24k Gold Plated RCA and the Nover (UK) capacitors have been specially manufactured on Audio-Gd specifications.
INGREDIENTS
Interface / ConverterSaber ES9018
INPUTS
USBUsb x1
CoaxialRCA + BNC
ToslinkOptical x 1
EXITS
AnalogRCA x 2
ACSSACSS x 2
Features:/ Strong>
  • USB interface: USB 32 (VIA VT 1731)
  • DSD (64 and 128) / DXD / PCM
  • DAC: ES9018
  • High accuracy TCXO clock
Ratio RCA Signal / Noise
116dB
Output impedance
10 ohms
RCA Output Level
2.5V (RCA)
2MA (ACSS)
Input sensitivity
0.5 Vp-p (75 Ohms, Coaxial)
19 dBm (Optical)
USB1.1, USB2.0 (Full Speed, High Speed, Class2)
ACSS Output Level
2 MA
Frequency Response
20Hz - 20KHz -0.2DB
Supported sampling rates
USB model: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz, 352.8kHz, 384kHz
Coaxial model: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 192kHz
Optical model: 44.1kHz, 48kHz, 88.2kHz, 96kHz
DSD 64/128
DXD
Dimensions
Weight
240 x 320 x 80mm
5KG
Accessories
AC power cord X1
USB cable X1
