AUDIOPHONICS U-Sabre USB DAC 24Bit/96kHz SA9023/ES9023 V2.2B
Audiophonics U-Sabre USB DAC 24Bit/96kHz SA9023/ES9023 V2.1B
4.8 / 5
Reference : 5807
49,90 €tax incl.
41,58 € tax excl.
Shipping from France
Billing in France
Technical support in France
The U-Sabre is back to us today in a version 2.2B with musicality further improved and now featuring a modern USB interface.
The U-Sabre 2.2B is a USB to S / PDIF / RCA converter.
Used in digital output this device acts as a particularly powerful digital interface.
Note: This product does not have an output or optical input.
Characteristics :
  • USB mode: Adaptive
  • DAC Mode: Asynchronous (the ES9023 Sabre has its own clock)
  • Direct-out: Without output capacitors
  • Dimensions: 65x70x25 mm
  • USB Interface: SA9023 (SAVIAUDIO): 16/24 Bit and 32KHz, 44.1KHz, 48KHz, 88.2Khz, 96KHZ
  • Digital to analog converter (DAC): Sabre ES9023
  • Inputs: USB and I2S (chips on the PCB)
  • Outputs: Line Jack 3.5mm + RCA Stereo (1.7V)
  • Does not require external power supply
  • High precision clock for an extremely low Jitter.
  • ASIO support
  • Product delivered naked (no connection or instructions for use)
  • USB: we recommend the use of qualitative cable and length less than 1.5m
  • Native / Plug & Play on Windows, Linux, OSX
https://www.audiophonics.fr/images2/5807/micougnou.jpg
[Img-14856-left-thickbox_default]
Schematic diagram :
https://www.audiophonics.fr/images2/5807/U-SABRE%20SCHEMATIC.jpg
Illustration: It is possible to provide the U-Sabre the 5V it needs thanks to an external power supply
in order to get rid of the noise generated by switching power supplies commonly used in computing.
https://www.audiophonics.fr/images2/8476/8332_audiophonics_usabre_cordon_alim_.jpg
https://www.audiophonics.fr/images2/8476/5807_audiophonics_u-sabre_alimentation_1.jpg
- FoodLinear Stabilized N 5V 5A V-DAC Black V3.0
Available in DIY version:
https://www.audiophonics.fr/images2/8427/8427_audiophonics_usabre_module_diy_sabre_3.jpg
OutputJack 3.5mm
DAC / ADC ChipES9023
Max sampling rate96kHz
22 reviews
Problème de soudure
Je n'ai peut-être pas eu de chance, mais je suis tombé sur un exemplaire qui a des mauvaises soudures sur les connecteurs de sorties. J'ai donc des faux contacts qui m'ont gâché la soirée du nouvel an. Dommage.
This review has been posted for AUDIOPHONICS U-Sabre USB DAC 24Bit/96kHz SA9023/ES9023 V2.2B
petite boîte musicale
Afin de franchir un premier pas dans la musique dématérialisée, j'ai donc passé commande de ce petit joujou, avec une batterie externe et rca pour une liaison qualitative.
Utilisé sous Daphile sur un amplificateur Denon pma 280 et enceintes BW dm 302, après 20h de rodage, mes cd rippés sonnent mieux que sur mon lecteur cd Philips 720.
La sonorité est très analogique, fluide et la dynamique et placement stéréo se mettent en place au fil des heures.
je ne puis que recommander ce petit dac, même le rendu sur les radio streaming en bas debit y gagnent en qualité, ainsi que la musique compressée.
SUPER PRODUIT !
Je l'ai reçu aujourd'hui via TNT, vous avez assuré je l'attendais impatiemment.
Je l'ai configuré avec la version 2.1.5 de VLC Media-Player et ça marché sans souci.
Je recommande ce produit à tous ceux qui hésitent encore c'est le meilleur qualité/prix.
J'avais l'intention de changer des enceintes mais vue la qualité du son (j'ai joué FourFiveSeconds) que ça envoi j'ai changé d'avis et je garde mes enceintes et du coup j'ai réalisé une économie.
Merci pour votre professionnalisme continuez comme ça et ne lâchez rien.
excellent !
Comme dit précédemment, un petit boitier qui fait un travail formidable... ou comment élever son système pour 49,90 euros...
Je ne peux plus me passer de ce dac ! Je ne possède pas, et n'ai jamais testé d'autres dac.
Mais, ayant été musicien amateur ( 30 ans ) de bon niveau, je peux juste dire que cet appareil vous amènera dans des conditions d'écoute proche du réel ( avec un enregistrement originel de bonne qualité ). A bas volume, c'est bien... augmentez le son, et là !!! ça ne sature pas, on a envie d'en remettre.
Pour le prix , aucune hésitation.
Je l'utilise avec ampli Denon PMA 1315R + Cabasse Doris M2 + Caisson de basses.
Merci à Audiophonics
complément à mon avis du 16/11/2014
Je la trouve de plus en plus fantastique cette petite machine.
Deux précisions : lorsque l'on plug un casque (70ohms pour moi) on perd une quinzaine de DB sur la sortie ligne, donc en écoute ligne ne pas laisser une prise casque branchée.
Le driver du dac ne coupe pas complètement la gestion du son Windows, c,a,d que le volume et la balance Windows restent activent.Donc avec foobar2000 il faut veiller a bien avoir la banlance au milieu ( une écoute au casque de bruit rose permet de bien faire la manip, car même curseur visuellement au milieu on peut perdre quelques db sur un canal, faire le réglage avec les flèches du clavier) Mettre aussi le volume Windows au maximum et faire le réglage final du volume avec foobar2000.
Le driver indiqué sur le site ne suffit pas il faut aussi installer asio4all, (sous xp et seven) et bien sélectionner assio4all comme sortie dans foobar2000.
Bonnes écoutes
