Maverick Audio TubeMagic D1 Plus DAC TE7022 Coaxial / Optical / USB
By buying this product you get 23 loyalty points
Reference : 8046
239,00 €tax incl.
199,17 € tax excl.
Maverick Audio TubeMagic D1 More DAC TE7022 Coax / Opt / USB
Rare converter equipped with a tube output stage is able to revive the most emaciated digital music.
Equipped with a source selector and a high-performance headphone amplifier, it is delivered here in its edition "plus".
True "base" Hifi, it will find its place in any dematerialized system or as an update on a CD deck.
Characteristics :
    • Inputs: Optical (Toslink), Coaxial (RCA), USB, Analog (RCA) and Line-in Jack 3.5 mm
    • Outputs: stereo RCA (variable volume output), stereo RCA with tube preamp (variable volume output)
    • Sample rates Digital inputs: 32khz, 44.1Khz, 48Khz, 88.2Khz, 96Khz, 192Khz
    • Sample rates USB input: 32khz, 44.1Khz, 48Khz, 96Khz
    • Audio Formats: 16, 20, or 24-bit linear PCM
    • Converter (DAC): CS4398
    • Amplifier Headphone: 16/600 ohms (1000mW ~ 300mW) output on 3.5 mm jack
    • Harmonic distortion:> 0.001% conventional output, 0.1% tube preamp output
    • Linear regulators: on converter and line outputs
    • Signal / Noise Ratio: RCA outputs (107db); Output RCA Tube (> 100db)
    • Output Impedance: 5K ohms
    • Volume control: on all outputs
    • Case: Brushed Aluminum Black
    • Dimensions: 260 x 55 x 167 mm
    • </ Ul>
Contents of the box:
      • Maverick Audio TubeMagic D1 Plus
      • Getting Started Guide
      • 3.5 mm jack / jack cable (Android, Apple, PC etc. sources)
      • Gold Plated 6.35 to 3.5 Plug Adapter
      • Power cable
PDF Manufacturer
https://www.audiophonics.fr/images2/8046/8046_MAVERICK_AUDIO_D1_PLUS_1.jpg
https://www.audiophonics.fr/images2/8046/8046_MAVERICK_AUDIO_D1_PLUS_3.jpg
https://www.audiophonics.fr/images2/8046/8046_MAVERICK_AUDIO_D1_PLUS_2.jpg
https://www.audiophonics.fr/images2/8046/8046_MAVERICK_AUDIO_D1_PLUS_4.jpg
Usage Scenarios
From a digital source:
https://www.audiophonics.fr/images2/8046/8046_MAVERICK_AUDIO_D1_PLUS_5.jpg
From a PS3, Xbox or other game device:
https://www.audiophonics.fr/images2/8046/8046_MAVERICK_AUDIO_D1_PLUS_6.jpg
From a CD, DVD, Blu-Ray player:
https://www.audiophonics.fr/images2/8046/8046_MAVERICK_AUDIO_D1_PLUS_7.jpg
From a PC or Mac computer
https://www.audiophonics.fr/images2/8046/8046_MAVERICK_AUDIO_D1_PLUS_8.jpg
Since an Android smartphone, Apple or a tablet:
https://www.audiophonics.fr/images2/8046/8046_MAVERICK_AUDIO_D1_PLUS_9.jpg
Technical comparisons D1, D1 +, D2
https://www.audiophonics.fr/images2/8050/8050_MAVERICK_AUDIO_D2_5.jpg
