FURUTECH FP-202 (G) Gold-plated Banana Plates Ø5.5mm (Set x4)
By buying this product you get 33 loyalty points
Reference : 2125
115,00 €tax incl.
95,83 € tax excl.
Shipping date: 20-11-2026.
High performance banana plugs with gold-plated Copper contacts .
Its use for the transit of low voltage signals is also justified by its low electrical resistance.
It is all the more effective in its role as a driver that it benefits here from the anti-magnetism proprietary processFURUTECH Alpha α, lequel takes place 2 steps:
1- Cryogenization of metals by -250 ° C with the aid of liquid nitrogen in order to consolidate their molecular structure and to improve their conductivity significantly.
2- Submission of these same metals to a powerful magnetic field created by means of magnets arranged in rings and whose attraction force is constantly controlled so as to leave no residual magnetic at the end of the treatment.
The FURUTECH FP-202 tube connectionto ensure contact with the speaker terminals. When the plug is connected, the cylinder, divided into two parts along a sinusoidal line , ensures a constant and regular pressure over its entire surface.
Internally, the cable is fixed by means of 2 screws to the specially designed shape to maximize the contact surface, and ensure a firm and durable hold. The FP-202 can also be welded for increased reliability .
Characteristics :
  • 24k Gold plated copper alloy body treated with Anti-magnetism "Furutech Alpha α"
  • Connection: Screw
  • Dimensions:
    • 12mm diameter
    • 26mm in height
    • 46mm in length
  • Compatible with cable up to 5.5mm in diameter
  • Delivered in box of 4 with wrench
Max cable diameter (mm)5.5
Mounting typeTo screw
ConnecticMale
ConnectorBanana
13 reviews
FICHES BANANE EXCELLENTES
Je n'ai pas encore installées celles-ci mais j'ai déjà un jeu de 4 (achetées chez Audiophonics) que j'utilisent depuis plusieurs années.. rien à redire c'est du Furutech. le son n'est pas montant notamment ce que l'on pourrait croire sur les mediums ou les aigus. NB Je remercie une fois de plus la diligence d'Audiophonics. J'ai commandé mes fiches + cables le lundi soir reçus tout ce petit monde le mercredi en parfait état. Merci encore
This review has been posted for FURUTECH FP-202 (G) Gold-plated Banana Plates Ø5.5mm (Set x4)
Rapport prix satisfaction au top
En remplacement des KLEI CLASSIC HARMONY BANANA (decevantes), je retrouve un haut de spectre incisif et lumineux. Qualité de fabrication et gain audibles au RV: Pas d'erreur ou regrets possibles avec ce materiel.
Very good for heavy cables. Audio quality signal is preserved
This bananas are amazing. And I am not talking about the sound quality that is preserved unaltered. It's very good made, thick and very resistant gold plating.
One of the best thing is the angle of the cable connection. Due to this angle, a heavy cable will not put pressure on binding post or on bananas.
Do I need to mention that the screw-in clamping mechanism is very strong and efficient?
There is nothing minuses to mention about those bananas.
Impeccable
Bonjour,
J'ai commandé ces fiches bananes pour remplacer de très anciennes WBT , livraison rapide et sérieuse comme toujours.
les fiches sincèrement elles sont de très bonne qualité , d'un point de vue fabrication et résultat sonore. Je possède un bon système et la différence sonore est bien réelle .
Je recommande ces fiches sans hésitations.
Stéphane.
Qualité de fabrication et sonore.
Posées en remplacement d’ anciennes prises banane WBT, le gain musicale est très net.
Aigu plus détaillé, précis, plus clair, on gagne sur tout l’ensemble du spectre sonore, tout paraît plus défini . Ces prises sont d’une grande transparence et laissent semble-t-il passer l’intégralité du message sonore sans coloration ou altération.
