R-CORE Transformer 30VA 24-0-24V
Here is an R-CORE transformer, ideal for powering DAC or HiFi preamplifiers. The design and manufacturing quality of this transformer is impeccable, and will allow you to power your device in the best of ways.
Reference : 9749
19,90 €tax incl.
16,58 € tax excl.
Shipping date: 25-08-2026.
R-Core Transformer
30VA 24-0-24V
Transformateur R-Core 30VA 24-0-24V
Here is an R-CORE transformer, ideal for powering DAC or HiFi preamplifiers. The design and manufacturing quality of this transformer is impeccable, and will allow you to power your device in the best of ways. Moreover, it is equipped with a magnetic screen and an electrostatic screen.
The values of the secondary voltages of the transformers are the nominal load voltages. The no-load voltages will be slightly higher than those stated.
Power30VA
PrimaryRed - White : 0V - 115V
Orange - Blue ; 0V - 115V
Yellow & Green wire = electrostatic shield
SecondaryYellow - Black - Yellow : 24V-0-24V
Dimensions78 x 71 x 40mm
OutputOn flexible wires
Mounting panel included-
Weight560g
Wiring diagram to switch 115V to 230V
Primary voltage (V)2x 115.0
Secondary voltage (V)24.0
Power (VA)30.0
super transfo
la tension est légèrement supérieure au 24v annoncé, mais c'est normal, tension mesurée à vide 27v1
ce type de transfo est de très bonne qualité, il est parfait pour des applications audio type préampli, il peux remplacer avantageusement des transfos toriques beaucoup plus cher
This review has been posted for R-CORE Transformer 30VA 24-0-24V
Here is an R-CORE transformer, ideal for powering DAC or HiFi preamplifiers. The design and manufacturing quality of this transformer is...
