AUDIOPHONICS Module Softstart for control and delay for amplifier
4.7 / 5
Reference : 4155
21,90 €tax incl.
18,25 € tax excl.
Shipping date: 24-11-2026.
This card is used to control the ignition of an amplifier, it makes the function stand-by, soft-start and timer.
It limits the current supply through the supply capacitors and the transformer to ignition./ P>
This card does not remove the ignition pads, in this case it is an HP timeout card you need.
This card plugs directly into the 220V input
If no load is connected, you can find 220V output (capacitor in series)
When you activate the softstart it powers your amplifier through the thermistors.
After one second the 2nd relay switches on and connects the output directly to the 220V.
Characteristics :
  • Maximum relay current: 30A
  • Approx. 1sec delay
  • Switching by fugitive pushbutton low amperage or by trigger 2-12V
  • Thermistors of current limitation (soft-start)
  • Mounting Hole Distance 79.5mm
  • Card dimensions: 90x90x40mm
  • Weight: 430g
  • V1.02 is 230V MAX or 555 chip can be damaged
https://www.audiophonics.fr/images2/4155/4155_SOFTSTART_2.jpg
9 reviews
Took some figuring out but works now
I bought this soft start module to build an F5m from diyaudio. But initially, I could not get it to work. I have a main power switch on the back and wanted to overrule the switch options on the module. Had to change the jumper to connect the switch jumpers and shortcut the green connectors to mimic a switch being turned “on”.
It worked and now the relays switches nicely
This review has been posted for AUDIOPHONICS Module Softstart for control and delay for amplifier
fonctionne
fonctionne parfaitement . a voir dans le temps si les relais tiennent le coup .
Quality product
I am very satisfied with the purchase. The module arrived fast,undamaged - well packaged (wrapped in cardboard and taped, wrapped in protective paper and placed in a larger cardboard box and taped again - excellent).
I am also surprised by the thorough and clean production, where quality components were used (among others Japanese ELNA-RC2, Panasonic-FC and Korean Lelon 105° capacitors).
I haven't tested the product yet, because I'm still waiting for the remaining components, but from what I've seen, I can report that I'm satisfied with the decision for Audiophonics. Greetings from Slovenia.
Module satisfaisant et versatile
J'en ai équipé mon ampli de puissance, pour qu'il s'allume via une entrée déclencheur 12V.
Le *clic* est très audible mais bizarrement satisfaisant, on sait quand il s'allume ou s'éteint. Il pourrait être étouffé avec un montage sur amortisseurs, le mien est sur des entretoises laiton dans un boitier aluminium.
Très bien.
Branché en mode swith ON/OFF a bascule.
Marche bien. RAS
