Daniel W.
Connecteur
J'ai envoyé une photo et...
Moyen
Elle se retourne en...
Giacomo P.
No for me
Absolutely no!
List of products MUNDORF
Mundorf, a renowned German brand, is a benchmark in the electronic components sector for audio, especially capacitors, inductors, and coils. Its series such as the Mundorf MCap, Mundorf Supreme, and Mundorf EVO, are particularly famous for their superior quality, offering exceptional sound clarity and fidelity. These ranges are the result of in-depth research and meticulous development, aimed at providing components that significantly elevate audio performance. Mundorf is committed to innovation, using advanced materials and cutting-edge technologies to create products that exceed the expectations of audiophiles and professionals, ensuring an immersive and rich listening experience.
Mundorf logo officiel
  • Ref : 16127
    In Stock
    The development of Mundorf MResist Ultra resistors is based on the excellent tonal properties of the copper-manganese foil. Compared to all wirewound resistors, this film offers lower inductance. The copper is significantly softer than the metal oxide used in MOX resistors.
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16138
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16139
    39,90 € 33,25 €Ex.
    In Stock
  • Ref : 16143
    In Stock
    26,90 € 22,42 €Ex.
    In Stock
  • Ref : 16128
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16129
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16140
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16141
    In Stock
    17,90 € 14,92 €Ex.
    In Stock
  • Ref : 16130
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16142
    In Stock
    17,90 € 14,92 €Ex.
    In Stock
  • Ref : 16131
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16132
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16133
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 13615
    In Stock
    These coils are recommended for filtering bass speakers. Their low impedance improves impulse response for a loudspeaker with better handling.
    169,00 € 140,83 €Ex.
    In Stock
  • Ref : 1696
    The Zero Ohm Coil (ZOC) is a transformer sized coil. It is made of Feron, a high quality material that limits the induced distortion to a maximum. In the ZOC, the center space is calibrated and adjusted by hand between the two laminar cores.
    154,90 € 129,08 €Ex.
    In Stock
  • Ref : 1695
    159,90 € 133,25 €Ex.
    In Stock
  • Ref : 1697
    In Stock
    he Zero Ohm Coil (ZOC) is a transformer format coil. It is made of FERON, a high quality material that limits distortion to a minimum.
    164,90 € 137,42 €Ex.
    In Stock
  • Ref : 1707
    In Stock
    339,90 € 283,25 €Ex.
    In Stock
  • Ref : 1708
    In Stock
    359,90 € 299,92 €Ex.
    In Stock
  • Ref : 1709
    In Stock
    379,90 € 316,58 €Ex.
    In Stock
  • Ref : 1710
    In Stock
    399,90 € 333,25 €Ex.
    In Stock
  • Ref : 1694
    149,90 € 124,92 €Ex.
    In Stock
  • Ref : 1698
    169,90 € 141,58 €Ex.
    In Stock
  • Ref : 1699
    189,90 € 158,25 €Ex.
    In Stock
  • Ref : 1701
    199,90 € 166,58 €Ex.
    In Stock
  • Ref : 1702
    In Stock
    209,90 € 174,92 €Ex.
    In Stock
  • Ref : 1700
    145,90 € 121,58 €Ex.
    In Stock
  • Ref : 1703
    219,90 € 183,25 €Ex.
    In Stock
  • Ref : 1704
    279,90 € 233,25 €Ex.
    In Stock
  • Ref : 1705
    299,90 € 249,92 €Ex.
    In Stock
  • Ref : 1706
    319,90 € 266,58 €Ex.
    In Stock
  • Ref : 6078
    Metal foil coils are physically the best designed. The output quality is consistent up to 100kHz and unwanted capacitive loads are very low. The stability of the coil is also remarkable: thanks to the large contact area between the winding and the polypropylene insulator, vibrations are eliminated.
    679,90 € 566,58 €Ex.
    In Stock
  • Ref : 6079
    759,90 € 633,25 €Ex.
    In Stock
  • Ref : 6080
    Metal foil coils are physically the best designed. Output quality is constant up to 100kHz, and unwanted capacitive loads are very low. Coil stability is also remarkable: thanks to the large contact area between the winding and the polypropylene insulator, vibrations are eliminated.
    849,90 € 708,25 €Ex.
    In Stock
  • Ref : 6077
    629,90 € 524,92 €Ex.
    In Stock
  • 949,90 € 791,58 €Ex.
    In Stock
  • Ref : 6082
    1 059,90 € 883,25 €Ex.
    In Stock
  • Ref : 6083
    1 199,90 € 999,92 €Ex.
    In Stock
  • Ref : 6084
    1 295,90 € 1 079,92 €Ex.
    In Stock
  • 1 441,90 € 1 201,58 €Ex.
    In Stock
