FIIO KA11 Portable DAC USB-C
The FiiO KA11 is a portable DAC based on a CS43131 DAC chip for digital-to-analog conversion, along with SGM8262 operational amplifiers to amplify the signal. This compact portable DAC supports high-resolution streams up to PCM 32bit 384kHz and DSD256, and is capable of delivering up to 2x 245mW into 16 ohms.
Reference : 21646
34,90 €tax incl.
29,08 € tax excl.
FiiO KA11 Portable DAC USB-C to 3.5mm Jack CS43131 32bit 384kHz DSD256
Photo du FIIO KA11
The FiiO KA11 is a portable DAC based on a CS43131 DAC chip for digital-to-analog conversion, along with SGM8262 operational amplifiers to amplify the signal. This compact portable DAC supports high-resolution streams up to PCM 32bit 384kHz and DSD256, and is capable of delivering up to 2x 245mW into 16 ohms. It is compatible with many devices via plug and play (Mac OS, Windows, iOS and Android) and also supports gaming consoles (PS5, Switch) thanks to UAC2.0 and UAC1.0 protocol compatibility. In addition, the KA11 can be controlled via the FiiO Control application available on Android and iOS. To ensure stable signal transmission and protect it from interference, FiiO has chosen to use palladium-plated OFC copper conductors for the cable of its KA11 portable DAC.
Le circuit du FIIO KA11
FiiO KA11: Strong audio performance
The KA11 chipset, composed of an SA9312L USB interface, a CS43131 DAC chip, and an independent SGM8262 op-amp, delivers high-quality sound reproduction. This is achieved thanks to support for high-resolution PCM 32bit 384kHz and DSD256 streams, as well as amplification up to 2x245mW into 16 ohms and 2x200mW into 32 ohms, all while maintaining THD+N below 0.0006% and an SNR of 125dB.
FiiO KA11 : de bonnes performances audio
FiiO KA11 : une compatibilité étendue
FiiO KA11: Wide compatibility
The KA11 is plug-and-play compatible with Windows, Mac OS, Android and iOS operating systems. Moreover, its dual UAC2.0 and UAC1.0 operating modes make it compatible with Nintendo Switch and PS5 consoles.
FiiO KA11: Control application
The KA11 can be controlled via the FiiO Control application available on Android and iOS. This allows for volume adjustment, RGB display control, and the use of digital filters.
FiiO KA11 : application de contrôle
FiiO KA11 : un câble audiophile
FiiO KA11: Audiophile-grade cable
The cable used in the KA11 features palladium-plated OFC copper conductors for interference-free signal transmission.
Technical Specifications
Product typePortable DAC
DAC chipCS43131
Op-ampSGM8262
InputUSB-C
Output3.5mm jack female
Supported sample ratesPCM up to 32bit 384kHz
DSD up to DSD256
Output power2x 245mW @ 16 ohm (THD+N<1%)
2x 200mW @ 32 ohm (THD+N<1%)
2x 22mW @ 300 ohm (THD+N<1%)
SNR≥ 125dB (32 ohm A-WT)
Noise floorPO <1.7uv 32 ohms A-WT
Output impedance< 0.7 ohms (32 ohms)
THD+N< 0.0006% (32 ohms) / < 0.00038% (300 ohms)
Dimensions44.5 x 9.7 x 10.5mm
Cable length65.5mm
Weight8.5g
Packaging1x FiiO KA11
OutputJack 3.5mm
DAC / ADC ChipCS43131
Max sampling rate384kHz
Max sampling rateDSD256
TOP !!!
Acheté pour palier un problème de puissance en sortie son de mon smartphone sur ma chaîne hifi vintage des années 90, ce petit dispositif a résolu parfaitement mon problème ! Je peux écouter à nouveau avec plaisir mes playlists enregistrées ainsi que mes radios internet préférées, sans déperdition du son. Franchement, j'ai voulu tester et au final, je ne regrette pas du tout mon achat ! Je conseille pour les personnes qui souhaitent faire comme moi avec un système audio déjà ancien.
This review has been posted for FIIO KA11 Portable DAC USB-C to Jack 3.5mm CS43131 32bit 384kHz DSD256
The FiiO KA11 is a portable DAC based on a CS43131 DAC chip for digital-to-analog conversion, along with SGM8262 operational amplifiers to amplify...
