PANGEA PREMIER XL RCA Interconnect Cable 1.5m (Pair)
These Pangea Premier XL RCA cables feature exceptional craftsmanship, with 100% Cardas Grade One copper conductors—considered the finest copper available—and are shielded by a triple-layer EMI/RFI shield consisting of silver-plated aluminum mylar. Furthermore, these high-purity copper strands are encased in PE tubing (superior to PTFE) that uses air as a natural insulator, a system derived from Pangea’s high-end cables.
By buying this product you get 34 loyalty points
Reference : 21669
349,00 €tax incl.
290,83 € tax excl.
Pangea Premier XLRCA Interconnect Cable Cardas Copper Gold Plated 1.5m (Pair)
Pangea Premier XL: Non-magnetic RCA connectors made of tellurium copper
A good cable is nothing without high-quality RCA connectors and superior contact. The Prime 750 RCA connectors, made of tellurium copper (with a center pin featuring 98% IACS conductivity) and designed for low mass (to reduce eddy current effects), have been specially developed to offer premium materials and a clean connection to RCA sockets thanks to a carefully engineered mechanical design. Furthermore, the outer body of this RCA connector is made entirely of non-magnetic polymer insulation, offering exceptional electromechanical performance. All Prime 750 RCA connectors are gold-plated and feature a beryllium copper cold spot.
Pangea Premier XL: High-quality craftsmanship and cutting-edge design
The outer jacket of the Pangea Premier XL cable is made of a special thermoplastic rubber that offers superior mechanical resistance to stretching and reduced static electricity.
Product typeRCA cables
Length1.5m
ConnectorsMale RCA
Cable conductors materialCardas Grade One copper
Cable insulationPE Air Tubes
EMI / RFI shielding materialTriple insulation using silver-plated foil and aluminum Mylar
Sheath materialHigh-resistance thermoplastic
Connector contact materialsCenter pin: Tellurium copper IACS 98%
Cold contact: Berrylium
Welding typeHand-soldered and hand-assembled cable
PackagingSold in pairs
Length (m)1.5
ShieldingYes
Section (mm²)N/A
ConnectorRCA
Conductors material (Cable)Cardas Copper
PANGEA PREMIER XL RCA Interconnect Cable Cardas Copper Gold Plated 1.5m (Pair)
These Pangea Premier XL RCA cables feature exceptional craftsmanship, with 100% Cardas Grade One copper conductors—considered the finest...
