DOUK AUDIO M1 MAX Integrated Amplifier
The Douk Audio M1 MAX is a compact Class D stereo amplifier designed to efficiently drive a wide range of passive speakers. It is based on the TPA3255 chip, known for its excellent efficiency and low distortion, allowing it to reach a maximum power of up to 2x250W depending on the power supply used. It is supplied here with a 48V 5A power supply delivering up to 2x120W into 4 ohms.
Reference : 21656
139,00 €tax incl.
115,83 € tax excl.
Shipping date: 19-11-2026.
Douk Audio M1 MAX Class D Integrated Amplifier TPA3255 Bluetooth 5.1 aptX HD 2x120W 4 ohms
Photo of the Douk Audio M1 MAX
It features comprehensive connectivity including Bluetooth 5.1 inputs (SBC, AAC, aptX, aptX HD), stereo RCA, and USB playback (U-disk), ensuring wide compatibility with smartphones, computers, and many other devices.
On the output side, it offers speaker binding posts (banana plugs compatible) as well as a 3.5mm AUX output allowing connection of an active subwoofer or a second amplifier for a 2.1 or more complex setup.
The unit benefits from high-quality audiophile components such as Rubycon capacitors, WIMA coupling capacitors, and pure copper inductors, ensuring clean and detailed sound reproduction.
Its technical performance includes an SNR ≥110dB, THD+N of 0.01%, and a frequency response of 20Hz to 20kHz (±1dB), ensuring accurate and dynamic reproduction.
Douk Audio M1 MAX: High-power Class D TPA3255 amplification
The M1 MAX uses the TPA3255 chip from Texas Instruments, a benchmark in modern Class D amplifiers. This architecture offers excellent energy efficiency, low heat generation, and strong current capability, allowing it to effectively drive most home speakers.
Depending on the power supply used (24V to 48V), output power varies significantly, reaching up to 250W per channel, with typical values ranging from 65W to 185W RMS depending on impedance and power supply (48V 5A power supply included).
This flexibility allows the amplifier to adapt to different uses, from compact HiFi systems to more powerful installations.
Douk Audio M1 MAX: High-quality Bluetooth 5.1 aptX HD
The integrated Bluetooth module is based on a QCC304X chip, compatible with SBC, AAC, aptX, and aptX HD codecs. This ensures stable wireless transmission, low latency, and audio quality close to wired connections. The M1 MAX is therefore an ideal solution for streaming from smartphones, tablets, or computers.
Douk Audio M1 MAX: Audio controls and ergonomics
The amplifier offers a simple and efficient interface with:
  • Volume control
  • Bass / treble adjustment (±6dB)
  • Source selector
  • Multimedia control buttons (play, next/previous track)
Status indicators allow real-time visualization of the active source, making daily use easier.
Overview of the Douk Audio M1 Max
1Input selector
2Input indicator
3Previous
4Play/Pause
5Next
6Bass control
7Treble control
8Power/volume control
9Bluetooth antenna
10USB-Host input
11RCA input
123.5mm AUX output
13Speaker terminals
1424-48V DC power input
Technical specifications
Product typeIntegrated amplifier
Amplifier chipTPA3255
Bluetooth chipQCC304X
Inputs1x Stereo RCA
1x USB-A Host
Bluetooth
OutputsSpeaker terminals
1x 3.5mm AUX jack
Supported Bluetooth codecsSBC, AAC, aptX, aptX HD (48KHz/24bit)
Supported U-Disk sample rate48KHz/16bit
U-Disk formatFAT-32
Max U-Disk capacity32GB
SNR≥ 110dB
THD+N0.01% @ 1kHz
Frequency response20Hz-20kHz (±1dB)
Input sensitivity1.4V
AUX output level1.6V
Bass/treble adjustment±6dB
M1 MAX Output Power
32V 5A power supply78W+78W @ 4 ohms
71W+71W @ 6 ohm
65W+65W @ 8 ohm
36V 6A power supply107W+107W @ 4 ohms
100W+100W @ 6 ohms
94W+94W @ 8 ohms
48V 5A power supply120W+120W @ 4 ohms
110W+110W @ 6 ohms
102W+102W @ 8 ohms
48V 10A power supply250W+250W @ 4 ohms
210W+210W @ 6 ohms
185W+185W @ 8 ohms
Power supply24-48V via DC jack
Dimensions155 x 125 x 42mm
Weight800g
Package contents1x Douk Audio M1 MAX
1x Bluetooth antenna
1x 48V 5A power supply
OutputJack 3.5mm
OutputSpeaker terminal
Channel2 (Stereo)
Power (W)120.0
DOUK AUDIO M1 MAX Integrated Amplifier Class D TPA3255 Bluetooth 5.1 aptX HD 2x120W 4 Ohms
The Douk Audio M1 MAX is a compact Class D stereo amplifier designed to efficiently drive a wide range of passive speakers. It is based on the...
