The Ampapa Q1 is a high-performance desktop DAC / headphone amplifier designed for audiophiles seeking versatility, precision, and sound customization. It features a dual DAC architecture combining ESS9039Q2M and AK4493 chips, paired with an XMOS XU316 USB interface for high-resolution audio processing up to PCM 768kHz 32bit and DSD512.
The Q1 also integrates a Bluetooth 5.2 module supporting SBC / aptX / aptX-HD, as well as an analog stage based on 4 interchangeable LM49720 op-amps in DIP8 format, allowing fine tuning of the sound signature.
In terms of connectivity, it is extremely complete with USB-C inputs (UAC 1.0/2.0), optical, coaxial, and Bluetooth, along with outputs including single-ended RCA, balanced TRS Jack 6.35mm, and a 3.5mm headphone output capable of delivering up to 1000mW at 32Ω with two gain levels.
Its technical performance is outstanding, with extremely low THD+N (0.0002%), SNR ≥120dB, and a linear frequency response from 20Hz to 20kHz (±0.2dB), ensuring precise, dynamic, and transparent sound reproduction.
The Q1 adopts a selectable dual DAC architecture, allowing you to choose between two distinct sound signatures depending on your preferences or music.
This flexibility goes even further, as it is possible to assign a different DAC to each output (line or headphone), offering advanced system customization.
The Q1 is equipped with 4 LM49720 operational amplifiers mounted on DIP8 sockets, easily accessible via a top panel. This allows advanced users to replace the op-amps with other compatible models to fine-tune the sound signature.
The headphone stage also features two gain levels, allowing output power to be adapted to different types of headphones:
This configuration allows efficient driving of headphones ranging from 16Ω to 600Ω, whether sensitive IEMs or high-impedance headphones.
The integrated Bluetooth 5.2 module ensures stable and high-quality wireless transmission, with support for SBC, aptX, and aptX-HD codecs. This allows you to enjoy high-quality audio streaming from a smartphone, tablet, or computer, with low latency and reliable connection stability.
The Q1 stands out with a refined and modern design, featuring a multifunction OLED display showing in real time: active source, selected DAC, volume, and USB mode.
The device also offers 11 dynamic display modes, including retro VU meters, audio spectrums, vinyl or cassette animations, adding an immersive visual dimension to your Hi-Fi setup.
Finally, its customizable RGB lighting, brightness settings, and remote control further enhance the user experience, allowing full control and seamless integration into any audio system.
| 1 | OLED display |
| 2 | IR receiver |
| 3 | 3.5mm headphone output |
| 4 | Control knob |
| 5 | RCA / 6.35mm TRS outputs #1 |
| 6 | RCA / 6.35mm TRS outputs #2 |
| 7 | Coaxial input |
| 8 | Optical Toslink input |
| 9 | 12V trigger output |
| 10 | USB-C input |
| 11 | Bluetooth antenna |
| 12 | DC 12V power input |
Technical specifications
| Specifications | |
| Product type | DAC |
| Switchable DAC chips | ESS9039Q2M + AK4493 |
| USB interface | XMOS XU-316 |
| Bluetooth chip | QCC304X |
| Op-amps | LM49720 |
| Inputs | 1x USB-C input 1x Optical Toslink 1x Coaxial Bluetooth |
| Outputs | 2x Single-ended stereo RCA 2x Balanced stereo 6.35mm TRS jack 1x 3.5mm jack headphone output |
| Other connectivity | 12V trigger output via 3.5mm jack |
| Supported sampling rates | USB: PCM up to 32bit 768kHz, DSD up to DSD512, DoP256 Optical Toslink, coaxial: PCM up to 24bit 192kHz, DSD DoP64 Bluetooth 5.2: 24bit 48kHz |
| Supported Bluetooth codecs | SBC, aptX, aptX-HD |
| Compatible USB OS | W10/W11/macOS/Linux/Android/iOS |
| Frequency response | 20Hz-20kHz (±0.2dB) |
| THD+N | 0.0002% |
| SNR | ≥ 120dB |
| Max output level | RCA: 2V 6.35mm TRS: 4V |
| USB driver modes | UAC 1.0/2.0 |
| Input sensitivity | 0dBFS |
| OLED display | 11 visualization modes + 1 operating status mode |
| 3.5mm headphone output specifications | |
| Max headphone output power | High gain: 1000mW @ 32Ω Low gain: 380mW @ 32Ω |
| Recommended headphone impedance | 16-600Ω |
| General | |
| Power supply | DC 12V via DC jack 5.5x2.1mm |
| Dimensions | 155 x 124 x 42mm |
| Weight | Net: 643g Gross: 1.2kg |
| Package contents | 1x Ampapa Q1 1x Bluetooth antenna 1x USB-A/C to USB-C cable 1x Optical Toslink cable 1x 3.5mm trigger cable 1x IR remote control 1x 12V DC Power supply |
| Input | SPDIF |
| Input | Bluetooth |
| Input | USB |
| Input | Optical |
| Output | RCA |
| Output | Jack 6.35mm |
| Output | Jack 3.5mm |
| DAC / ADC Chip | ES9039Q2M |
| DAC / ADC Chip | AK4493 |
| Color | Black |
| Networking | No |
| Remote Control | Yes |
