SMSL VMV D3R Balanced DAC
The SMSL VMV D3R is an ultra high-performance DAC based on audiophile-grade components. For digital-to-analog conversion, it integrates two ROHM BD34302EKV DAC chips for fully balanced signal processing, combined with an XMOS XU316 USB interface supporting streams up to PCM 32bit 768kHz and DSD512.
By buying this product you get 174 loyalty points
Reference : 21613
1 749,00 €tax incl.
1 457,50 € tax excl.
Shipping date: 25-11-2026.
SMSL VMV D3R Balanced DAC 2x ROHM BD34302EKV Bluetooth LDAC 32bit 768kHz DSD512
Photo du SMSL VMV D3R
The SMSL VMV D3R is an ultra high-performance DAC based on audiophile-grade components. For digital-to-analog conversion, it integrates two ROHM BD34302EKV DAC chips for fully balanced signal processing, combined with an XMOS XU316 USB interface supporting streams up to PCM 32bit 768kHz and DSD512. It also features OCXO oscillators and a CK-04 clock circuit for optimal jitter reduction, along with a fully balanced analog volume control preserving signal integrity. Regarding power supply, the SMSL VMV D3R uses two toroidal transformers, each independently powering the digital and analog circuits. In terms of connectivity, it includes Bluetooth with support for AAC, SBC, aptX HD and LDAC codecs, as well as a full range of digital inputs (USB-C/B, I2S via HDMI, coaxial SPDIF, optical Toslink, etc.) and RCA and balanced XLR outputs. Full and intuitive control of the SMSL VMV D3R is achieved via a remote control and an LCD screen located on the front panel.
SMSL VMV D3R: Audiophile architecture
The SMSL VMV D3R circuit is built with high-quality components, featuring separate analog and digital processing to prevent interference. Two toroidal transformers provide a stable power supply. The fully symmetrical design helps reduce noise and preserve detail.
SMSL VMV D3R : une architecture audiophile
SMSL VMV D3R: Balanced DAC
The SMSL VMV D3R is built around two ROHM BD34302EKV DACs and an XMOS XU316 USB interface, offering support for high-resolution audio streams up to 32-bit/768kHz PCM and DSD512. These DAC chips are renowned for their natural sound signature, dynamic range, and wide soundstage.
SMSL VMV D3R : DAC symétrique
SMSL VMV D3R : Horloge optimisé
SMSL VMV D3R: Optimized clock
Un oscillateur OCXO 10MHz et un circuit d'horloge CK-04 offrent une réduction du jitter et du bruit de phase pour un traitement du signal précis, résultant en une image sonore claire et précise.
SMSL VMV D3R: Analog volume control
The volume control is handled by a fully balanced analog circuit, preserving signal integrity and avoiding any added distortion.
SMSL VMV D3R : contrôle de volume analogique
SMSL VMV D3R : Bluetooth LDAC
SMSL VMV D3R: Bluetooth LDAC
Equipped with a Qualcomm Bluetooth chip, the SMSL VMV D3R supports high-resolution codecs: SBC, AAC, aptX, aptX HD and LDAC (24bit 96kHz). This feature provides a fast and convenient wireless connection without compromising signal quality.
SMSL VMV D3R: Dual toroidal transformers
The digital and analog circuits are powered independently thanks to two toroidal transformers. This avoids interference between circuits and ensures improved signal processing stability.
SMSL VMV D3R : Double transformateur torique
SMSL VMV D3R : Interface utilisateur
SMSL VMV D3R: A polished interface
The SMSL VMV D3R features a brand-new, clear, and user-friendly interface. It offers convenient features such as lyrics synchronization and the display of track information during Bluetooth playback.
In addition, this device offers a sound profile called “Best Set,” which allows you to automatically configure filter slopes, sampling rates, and gain compensation with a single tap.
Overview of the SMSL VMV D3R
Aperçu du SMSL VMV D3R
1Display
2Multifunction button
3IR receiver
4LED indicator
5Single-ended RCA output
6Balanced XLR output
7AES/EBU input
8Coaxial input
9USB-C input
10Bluetooth antenna
11USB-B input
12Optical Toslink input
13I2S input via HDMI
14External clock input
15AC power input
Technical specifications
Product typeDAC
DAC chip2x ROHM BD34302EKV
Inputs1x USB-C
1x USB-B
1x I2S via HDMI
1x Optical Toslink
1x Coaxial
1x AES/EBU
Outputs1x Single-ended RCA
1x Balanced XLR
Supported sampling ratesUSB, I2S via HDMI: PCM up to 32bit 768kHz, DSD up to DSD512
Optical Toslink, coaxial, AES/EBU: PCM up to 24bit 192kHz, DSD DoP64
MQA decoderUSB, Optical Toslink, coaxial, AES/EBU
Output levelRCA: 2.5Vrms
XLR: 5.2Vrms
THD+NRCA: 0.00013% (-117dB)
XLR: 0.00017% (-115dB)
Dynamic rangeRCA: 122dB
XLR: 123dB
SNRRCA: 122dB
XLR: 123dB
USB transmissionAsynchronous
USB compatibilityWindows 7/8/8.1/10/11 (with driver)
Mac OSX 10.6 and above, Android, iOS, Linux (driverless)
Supported Bluetooth codecsBluetooth 5.4: SBC, AAC, aptX, aptX HD, LDAC
Power supply100-240V AC
Power consumption< 30W
Dimensions320 x 51.5 x 280.9mm
Weight3.81kg
Package1x SMSL VMV D3R
1x Remote control
1x AC power cable
InputAES/EBU
InputI2S via HDMI
DAC / ADC ChipROHM BD34302EKV
Max sampling rate768kHz
Max sampling rateDSD512
Remote ControlYes
Very capable dac/preamp
I have listened to this dac and preamp for over two weeks now and can say that the dual rohm chip latest version is very smooth sounding with good detail and dynamics. When used as a preamp it is also very capable but can be improved upon if you have a better quality stand alone preamp. It may be beneficial for some to have more selection of i2s settings as there are only two which may or may not match your source i2s format. I have found that in the sound mode settings that mode 1 is more to my liking. The remote control is all aluminum and better quality than the usual plastic kind. Audiophonics were also very helpful in updating to the latest firmware 2.01 before it was shipped and I thank them for this.
This review has been posted for SMSL VMV D3R Balanced DAC 2x ROHM BD34302EKV Bluetooth LDAC 32bit 768kHz DSD512
The SMSL VMV D3R is an ultra high-performance DAC based on audiophile-grade components. For digital-to-analog conversion, it integrates two ROHM...
