Male / Female Extension GPIO 40 Pins Ribbon Cable for Raspberry Pi A / B 10cm
This ground cable allows the 40-pin GPIO connector to be offset from a Raspberry Pi 2 or 3. Especially useful for a DIY mounting in which you want to place a module next to your Raspberry Pi rather than above it for example.
This cable is not compatible with Raspberry Pi A and B.
| Specifications | |
| Product type | GPIO extension ribbon cable |
| Compatibility | Raspberry Pi 2 / Raspberry Pi 3 |
| Length | 10cm |
| Number of pins | 2x20 pins |
| Connectors genre | Male / Female |
| Pitch | 2.54mm |
| Length (m) | 0.1 |
| Shielding | No |
| Section (mm²) | N/A |
| Connector | GPIO |
| Conductors Plating (Cable) | None |
