FURUTECH FT-735SM(R) Jack 3.5mm Rhodium plated Ø5mm (Unit)
4.3 / 5
Reference : 7702
39,90 €tax incl.
33,25 € tax excl.
Shipping date: 25-09-2026.
Rhodium plated Jack 3.5mm connector ⌀5mm (Unit)
Furutech FT-735SM(R)
The 3.5mm Jack compatible FT-735 connectors have been shaped around Furutech's know-how.
This connector consists of an Alpha treated phosphor bronze conductor, Teflon insulation to minimize impedance and a non-magnetic stainless steel body to reduce damping.
ConductorOne piece Rhodium-plated α (Alpha) Pure copper conductor
Ground conductorRhodium-plated α (Alpha) Copper Alloy
InsulationSpecial grade Nylon Glass Fiber Resin
Cable clampCopper alloy
Housing materialStainless
Connection typeTo solder
Acceptable cable diameter5mm
Total length41mm
Housing dimensions10 x 25mm
ColorArgent
Sold by the unit-
Max cable diameter (mm)5.0
Mounting typeTo weld
ConnecticMale
Contacts number3
3 reviews
super fast shipping
The product is excellent. The seller is very relevant and helpful. Very fast shipping 2 days. This is my next favorite shopping company. Thank you very much for everything.
This review has been posted for FURUTECH FT-735SM(R) Jack 3.5mm Rhodium plated Ø5mm (Unit)
Great upgrade
Replaced the unbranded 3.5 mm connectors for my Hifiman Arya headphones on my custom made headphone cable. the spaciousness and smoother high frequencies were immediately noticeable. Worthwhile upgrade
très haute qualité
acquis pour cabler un senn i8, cela fait cher le connecteur mais au mois on peut soudé les deux - plus blindage, ce qui n'est pas le cas de la plupart des autres connecteurs jack
