FiiO RETRO BOX Portable Active Speaker Black
The FIIO RETRO BOX is a desktop Bluetooth speaker inspired by classic cassette players, specifically designed to pair with the FIIO JM21, M21, and M33 digital audio players while remaining fully compatible with a wide range of Bluetooth and USB-C audio sources.
Reference : 22253
55,00 €tax incl.
45,83 € tax excl.
FiiO RETRO BOX Portable Active Speaker USB DAC 32bit 96kHz Bluetooth 6.0 LDAC 2x 5.3W 65Hz-20kHz Black
FiiO RETRO BOX
The FIIO RETRO BOX is a desktop Bluetooth speaker inspired by classic cassette players, specifically designed to pair with the FIIO JM21, M21, and M33 digital audio players while remaining fully compatible with a wide range of Bluetooth and USB-C audio sources. Its 2+2 acoustic architecture combines two 40mm full-range drivers with two passive radiators, powered by a 2x 5W stereo amplifier to deliver dynamic and balanced sound reproduction. Featuring Bluetooth 6.0 with LDAC codec support, it enables high-resolution wireless audio streaming. The RETRO BOX can also operate as a USB DAC, supporting PCM audio streams at 44.1kHz, 48kHz, and 96kHz for direct connection to a computer. Its interface is compatible with the FIIO Control app, providing access to firmware updates as well as various audio settings and equalizer presets. Powered by two integrated 18650 batteries, it offers up to 15 hours of battery life. Its retro aesthetic is further enhanced by an animated interface simulating cassette playback when a compatible FIIO player is docked, creating an experience that is as visually engaging as it is sonically enjoyable.
FiiO RETRO BOX: 2+2 Acoustic Architecture and LDAC Bluetooth
The RETRO BOX features an acoustic design comprising two 40mm full-range drivers and two passive radiators, with each channel housed in its own dedicated acoustic chamber to minimize channel interference. Its amplifier delivers 2x 5W of output power, while Bluetooth 6.0 connectivity with LDAC support ensures high-quality wireless audio transmission with excellent stability. Several sound presets are available, allowing users to easily tailor the sound signature to their preferences.
FiiO RETRO BOX: USB DAC and FIIO Control App
In addition to Bluetooth connectivity, the RETRO BOX can be used as a USB DAC with a computer via its USB-C input, supporting PCM audio streams up to 96kHz. It is also compatible with the FIIO Control app, allowing users to perform firmware updates, select EQ presets, and customize various speaker settings. An integrated microphone also enables hands-free calling when the speaker is connected to a smartphone.
FiiO RETRO BOX: Retro Design and Seamless Integration with FIIO Players
Inspired by portable cassette players, the RETRO BOX was developed to accommodate the FIIO JM21, M21, and M33 digital audio players. Once connected via Bluetooth, these players trigger a graphical interface simulating the rotation of a cassette, enhancing the immersive visual experience. Powered by two 18650 batteries, the speaker offers up to 15 hours of battery life, making it equally suitable for desktop use or listening on the go. Its compact form factor and vintage-inspired design make it a unique audio solution that blends nostalgia with modern technology.
FiiO RETRO BOX Overview
1Power Button
2Play/Pause Button
3Previous Track
4Next Track
5Status LED
6Microphone
7Multifunction Button
Technical Specifications
Product TypePortable Active Speaker
InputsUSB-C
Bluetooth
Drivers2x Ø40mm 4Ω Full-Range Drivers
Output Power2x 5.3W
Frequency Response65Hz-20kHz
Supported Bluetooth CodecsSBC, LDAC
Supported Sampling Rate32bit 96kHz
Power Supply5V 2A
Battery Charging Time2.5h
Battery Life10.5h
Dimensions152.8 x 98.8 x 76mm
Weight683g
Package Contents1x FiiO RETRO BOX
1x USB-A to USB-C Cable
Lowest frequency (Hz)65
Highest frequency (Hz)20000
Power (W)5.0
Number of ways2
Number of loudspeakers2
Speaker typeActive
Speaker form factorOther
FiiO RETRO BOX Portable Active Speaker USB DAC 32bit 96kHz Bluetooth 6.0 LDAC 2x 5.3W 65Hz–20kHz Black
The FIIO RETRO BOX is a desktop Bluetooth speaker inspired by classic cassette players, specifically designed to pair with the FIIO JM21, M21, and...
