By buying this product you get 179 loyalty points
The Tonewinner SW-D6000 is a bass-reflex-loaded active subwoofer. This model features a large 38cm driver, powered by a 800W amplification stage. It also features a DSP for fine-tuning the subwoofer's settings to perfectly match your system and listening room. This SW-D6000 is ideal for a home-cinema installation, delivering deep, punchy bass for total immersion.
The Tonewinner SW-D6000's large 38cm-diameter driver is capable of descending very low and without distortion, to reproduce the bass of your music and films more than convincingly. It features a rigid diaphragm, limiting distortion even when the driver is subjected to considerable deflection..
The 800W amplifier stage ensures powerful, dynamic bass reproduction, enabling the subwoofer to respond effectively to the signal supplied. The SW-D6000 is thus capable of descending without difficulty to a frequency of 15Hz.
To perfectly match your audio system and listening room, the SW-D6000 comes with its own DSP and EQ directly accessible from the back of the cabinet. An LCD screen displays your settings in real time. These settings can also be accessed remotely via Tonewinner's free mobile application. Several predefined DSP modes are available, but you can also go further by customizing the subwoofer's equalization yourself.
The rear of the Tonewinner SW-D6000 features a dual LFE input in unbalanced RCA and balanced XLR formats, as well as an RCA line input and an RCA LFE output. The SW-D6000 is thus capable of integrating into the majority of home-cinema or even HiFi audio systems. What's more, its output allows the association of a second subwoofer.
1 | Input voltage selection |
2 | Power button |
3 | Power input |
4 | Fuse |
5 | Balanced LFE input |
6 | Single-ended LFE input |
7 | LFE output |
8 | RCA line input |
9 | Volume + / Volume - |
10 | Mute / OK |
11 | Menu |
12 | LCD screen |
13 | ON/OFF LED |
Product type | Active subwoofer |
Loudspeaker diameter | Ø38cm |
Amplification type | Class D |
Power output | 800W |
Frequency response | 15Hz - 220Hz |
Phase setting | 0 - 180° |
Impedance | 3Ω |
Cabinet material | MDF |
DSP / EQ | |
Inputs | 1x LFE XLR 1x LFE RCA 1x RCA line in |
Output | 1x LFE RCA |
Dimensions | 480 x 598 x 628mm |
Weight | 43kg |
Color | Black |
