By buying this product you get 99 loyalty points
This stylish DIY 100% Aluminum case with exceptional dimensions (620x480x260mm) with Vu-meter is equipped with high quality heat sinks as well as ventilated covers.
It is an ideal case to integrate a large and powerful high fidelity amplifier or any other audio editing.
It is equipped with a front hole for an ON / OFF Aluminum button, and a rear panel machining for the IEC socket for power supply.
Its robust and sophisticated design ensures an efficient assembly and use with a professional finish around an innovative design.
Note: Some housings are machined directly into the ground. Thus, certain angles and / or edges can be sharp.
Care should be taken when handling this type of enclosure.
Dimensions Internal:
External Dimensions:
Box sold to assemble.
Characteristics :
