Boitier avec de belles finitions. Il trouvera facilement une place dans une installation audio / video.
Merci Audiophonics !
This 100% Aluminum case has been designed by AUDIOPHONICS to receive the Raspberry Pi 2 / Pi 3 Model B & Audiophonics DAC I-Sabre V2 / V3 ES9023.
It has all the inputs / outputs necessary for its connector, its power (Jack DC 5.5 / 2.5mm), as well as an HDMI offset.
It has been designed with the aim of allowing you to have the effectiveness of your Raspberry Pi in a high quality Audio environment.
Thanks to this particularly elegant and discreet case, you have a high-performance audio solution at an excellent value for money.
Characteristics :
The housing drilling allows the AUDIOPHONICS I-Sabre DAC V2 line jack to be used for the 3.5mm Jack line output </ a> or the AUDIOPHONICS I-Sabre DAC V3 . The power supply is then via a USB-A port.
Screws supplied:
2x Nut HU Steel Zinc Plated M2x1.45mm
2x Screw TFHC countersunk head Carbon steel DIN7991 M2x16mm
4x Screw TFHC countersunk head Steel M2.5x5mm
4x Spacer M2.5 Brass screw thread 5mm
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
