This housing has a black brushed aluminum body and an elegant silver facade. These materials ensure this piece a robust, easy to dissipate heat as well as protection against naturelleme most electromagnetic interference that could affect the various processes involved in sound reproduction.
Two radiators located on each side of the housing further alleviate thermal stress, which makes this case a model entirely appropriate for sensitive functions to heat (amplifier, preamp ...).
For convenience, this case comes with its IEC receptacle.
The housing body is delivered already drilled regarding food. This will save valuable time for building followers in do it yourself.
| Characteristics | |
| Type | DIY housing 100% |
| external dimensions | 271 x 226 x 70mm |
| useful dimensions | 260 x 183 x 60 mm |
| Material | Brushed aluminum |
| Front face | 8.2 mm |
| rear | 3.7 mm |
| lateral surfaces | 9 mm |
| heaters | 230 x 60 x 12 mm (x2) |
| Delivered with | Screws IEC receptacle non-slip feet |
| Weight | 2.360 kg |
