These high-precision dual-mono amplifier modules deliver 100 W under 8 ohm. Equipped with precision metal resistors, high quality capacitors, this kit is ideal for high power amplification modules with high-fidelity sound.
This high quality Class AB amplifier module with 4 channels is capable of developing a power of 4x80W under 4Ω, thanks to a TDA7850 chip offering what is more a rich and musical sound reproduction. The latter is mounted on a large heatsink allowing to dissipate efficiently the heat released.
This low-cost yet highly efficient Class AB amplifier module is based on a TDA7377 chip allowing it to develop up to 2x30W under 4Ω. The quality components integrated in this module, such as Nichicon capacitors for filtering or gold-plated contacts, ensure a beautiful sound reproduction.
This Class D stereo amplifier module embeds a TPA3116 chip, capable of delivering 2x50W power under 4Ω or 2x30W under 8Ω with a high efficiency, higher than 92%, while offering a clear and detailed reproduction. It also integrates its own volume control allowing to easily adjust the volume level.
This Class D stereo amplifier module features a TPA3221 chip, capable of delivering 2x85 power at 4 Ohm with 92% efficiency, while guaranteeing clear, detailed reproduction with sub-1% total harmonic distortion. This module also incorporates its own volume control. The amplification chip is topped by a heatsink to efficiently dissipate the heat generated....
This small amplifier module uses a PAM8406 amplifier chip allowing it to deliver 2x3W power at 4Ω. The input is on a 3.5mm jack connector and the output on a screw terminal. This module will thus be able to be perfectly adapted for the design of a small amplified speaker.
This MA-LM01 stereo amplifier module is powered by two LM1875 TI amplifier chips. Thus, this amplifier is capable of delivering 2x20W at 8 Ohm with a distortion of only 0.015% (@ 1kHz).
The Connex MA-TA04 TA3020 3.1 is a Class T stereo amplifier module, based on a Tripath TA3020 amplifier chip. This one is thus able to develop a considerable power of 2x300W under 4Ω with a high efficiency of 92%, and this in a compact format.
This Mono Amplifier module is based on the use of a high power TDA7293 transistors developed by the Swiss firm ST MicroElectronics.It is capable of delivering a continuous power of 1x 100W under 4Ω.The filtering is ensured by 2 electrolytic capacitors 50V Chemi-Con of 5800uF each.
This Class AB amplifier module allows to develop a consequent power of 2x 125W in a compact form factor. It is based on the use of 25C5171, 2SA193, 2SC5171 transistors (four transistors in total), IRFP240 and IRFP9240 power MOSFETs and a UPC2581 voltage amplifier chip.
This Mono Amplifier module is based on the use of high-power TDA7293 transistors developed by the Swiss firm ST MicroElectronics.It is capable of delivering a continuous power of 1x 150W under 4Ω.
This dual mono amplifier is equipped with no less than 4 LM3886 amplification chips in total, to deliver 2x120W at 8 Ohms and accompany your hifi system as required.
This kit assembly will delight music lovers looking to learn about audio-centered electronics through a single project and leading to concrete results.
Purifi's EVAL1 stereo evaluation kit is designed to enable simple connection of the power supply and input/output signal to the 1ET400A Stereo amplifier module. The kit has been developed for evaluation purposes, but is also suitable for DIY applications.
Purifi's EVAL3 mono evaluation kit is designed to enable simple connection of the power supply and input/output signal to the 1ET7040SA amplifier module. The kit has been developed for evaluation purposes, but is also suitable for DIY applications.
Purifi's EVAL4 is an evaluation kit comprising a 1ET9040BA mono amplifier module and a FE04 mono input card. It is perfectly suited to integration in DIY audio projects. It is designed to facilitate testing of the 1ET99040BA, and provides all the connectivity and controls required to operate the amplifier module.
This Class A/B stereo power amplifier module is made of discrete components and can develop a power of 2x 125W under a 4Ω load and 2x75W under an 8Ω load. Specially designed for audiophile applications, it features high-quality components. The module accepts an unbalanced RCA signal (AUX) as well as a balanced XLR signal.
The Sylphaudio D100 P02 Class D amplifier module is designed to deliver high-quality sound, including exceptional midrange clarity and transparency. It is based on a TI TPA3251 amplifier chip, renowned for its superior performance in these areas.
The versatile Sylph Audio D400M Class D amplifier module benefits from a 2Ω load capacity, enabling it to effortlessly handle demanding loudspeakers while delivering high-quality sound reproduction with a very low level of distortion.
This TinySine TSA1200 control module has 5 buttons and is connected to an amplifier module of the brand (see list in the characteristics below). These buttons allow you to act directly on the playback of your audio files or the volume level.
This kit is designed for professionals and DIY enthusiasts alike. It includes a volume knob, a moisture-resistant LED, a 2.4GHz antenna and a TSA2210U amplifier board and Bluetooth receiver.
The TSA2300 is a Bluetooth 5.0 amplifier module, capable of delivering 2x13W power at 4Ω (1% THD+N). It takes advantage of a Class D architecture based on a MAX98400A amplifier chip. The strong point of this module is its ability to pair with other TSA2300s, and it can save the pairing information, so there is no need to perform this manipulation...
