Module de valeur, mais dommage que les borniers ne soient pas a la hauteur du résultat d'écoute en enceinte assistée
Based on the T-Class architecture of the famous TRIPATH brand, this AUDIOPHONICS amplifier module features high quality reproduction for a very compact product.
Amplifier module TRIPATH 2x90Watts
This new version uses more surface components, and a revised power supply (single diode bridge for ground loops). The input stage now accepts RCA and XLR signals with an AOP 5532. Based on the T-Class architecture of the famous TRIPATH brand, this AUDIOPHONICS amplifier module features high quality reproduction for a very compact product.
The integrated TA2022 chip can indeed reach 2 x 90 Watts under 4Ω with an extremely well controlled harmonic distortion level since not exceeding 0.1%. A power that in no way sacrifices to the precision of this prodigious circuit renowned connoisseurs for its musical virtues.
To protect your speakers, this board has a protection circuit against the possible presence of a DC component. A delay time also prevents unpleasant ignition noise. Jumpers are used to select the input: balanced (XLR) or unbalanced (RCA). This version is bridgeable to reach up to 150W under 4ohm.
| Specifications | |
| Output power per channel | 60W 8 Ohm (@ THD+N 0.1%) 90W 4 Ohm (@ THD+N 0.1%)  |
| Bridge output power | 150W 8 Ohm (@ THD+N 0.1%) |
| THD | 0.015% @ 45W 8 Ohm 0.015% @ 70W 4 Ohm  |
| SMPTE | 0.10 @ 25W 4 Ohm |
| Dynamic range | 102dB |
| Efficiency | 92% @ 88W 8 Ohm 87% @ 125W 4 Ohm  |
| Power supplt | Transformateur 2x20V or 2x20V 2.6A + 1x12V 1A + 1x9V 1A of 100-160VA |
| Dimensions | 200 x 80 x 35mm |
| Space between fixation holes | 70 x 190mm (M4) |
| Weight | 240g |
Two feeding options
Détail des entrées AC :
Balanced input: 9-pin connector
Selected unbalanced input: 3-way terminal block
| Input | Screw terminals |
| Output | Screw terminals |
| Channel | 2 (Stereo) |
| Class | Class D / T |
| Amplifier chip | TA2022 |
| Power (W) | 90.0 |
Average votes  4.6 / 5  9 reviews  | Why write products reviews ?  You can share your feelings about products and help other people by sharing your experience  |
rene a.
rene a.
Patrick T.
Gilbert C.
Philippe H.
