Refurbished product - Grade B
Slight snag on the side of the frame.
The Eversolo DMP-A6 Gen 2 is a HiFi audio streamer that seamlessly combines outstanding sound quality with cutting-edge technology. More than just an audio device, it's a new way of connecting to the world of music. From hardware design to audio processing, every detail of the DMP-A6 Gen 2 has been meticulously designed for audiophiles seeking the ultimate listening experience. It not only meets your listening needs, but transforms every listening experience into a wonderful artistic exploration.
The fully balanced design from decoder to output stage, combined with balanced XLR and unbalanced RCa interfaces, reduces distortion and extends the dynamic range. Whether connecting power amplifiers or active loudspeakers, the DMP-A6 Gen 2 guarantees more detailed and precise sound expression.
Two ESS ES9038Q2M high-performance DAC chips process the left and right channels independently, delivering astonishing dynamic range and detailed resolution. Even complex symphonies are clearly rendered, faithfully reproducing the soundstage and atmosphere of the recording.
The XMOS XU316 chip offers far greater processing power, supporting native DSD512 decoding and 32bit 768kHz PCM, guaranteeing high-resolution sound in its native quality, for rich, captivating playback.
High-precision clock oscillators, combined with optimized algorithms, reduce jitter to a minimum, guaranteeing stable, pure audio performance.
The new high-performance linear power supply stage operates at a very low noise level of just 40µV, providing a cleaner and more reliable power source.
The innovative Eversolo EOS proprietary audio processing engine bypasses SRC limitations and delivers high-fidelity sound quality. Whether playing local music or streaming audio via third-party applications, the EOS engine guarantees the best playback resolution.
The EVC engine uses a unique volume adjustment algorithm to precisely eliminate errors at different gain levels, ensuring that when volume is adjusted, the signal shape remains unchanged, providing the DAC with more complete and accurate audio information.
The Eversolo DMP-A6 Gen 2 supports a wide range of high-fidelity audio formats, including DSD, MQA, FLAC, APE and WAV, meeting the diverse needs of high-resolution audio enthusiasts. From classical to electronic music, you can always enjoy sound as pure as the original recording.
Thanks to advanced system integration, you can easily access Eversolo's personalized streaming services, such as TIDAL, Qobuz, Deezer, Amazon Music, Apple Music, Highresaudio, Presto Music, Radio Paradise and many others. So enjoy limitless music exploration and manage your music library effortlessly. The DMP-A6 Gen 2 supports numerous third-party applications with high-resolution direct audio output via the EOS audio engine.
The DMP-A6 Gen 2 not only boasts powerful playback and decoding capabilities, but also supports cross-platform addition of music files from local disks or network storage. It automatically classifies and displays information such as artists, composers, albums, genre, sample rate and more. It also supports functions such as quick search and the creation of a dedicated music library.
Audio files must contain ID3 metadata.
Le Eversolo DMP-A6 Gen 2 seamlessly supports DLNA, Roon and TIDAL Connect, integrating your digital music ecosystem and optimizing your music streaming experience. With a simple touch of the screen or via the mobile app, you can easily switch sources and immerse yourself in your music without delay.
The multi-platform global music library integrates favorites from various online music platforms. Thanks to intelligent categorization and search, it's never been easier to find your favorite tracks.
Thanks to multiple integrated music services, you can easily customize your own hybrid playlists and queues. Whether it's tracks from different platforms or a mix of different musical styles, the DMP-A6 Gen 2 can integrate them seamlessly.
Thanks to the DMP-A6 Gen 2's professional equalizer, you can easily adapt settings and parameters to suit your personal preferences. It offers precise equalizer gain settings and fine volume balancing for left and right channels.
Easily share local files between devices on your local network without additional configuration, and enjoy extremely convenient music sharing.
Ample memory ensures stable multitasking, while 32GB of internal storage is perfect for storing high-quality audio files and system resources.
The SSD slot underneath supports NVMe M.2 SSDs up to 4TB, allowing you to expand your music library. The high-speed interface ensures instant loading and playback, for a smooth, stable experience.
The SSD is sold separately.
The DMP-A6 Gen 2's powerful Quad Core processor delivers high performance, making decoding, browsing and multitasking seamless. Whether loading large files or processing high-quality audio streams, the processor handles these tasks effortlessly.
HDMI ARC connectivity on the Eversolo DMP-A6 Gen 2 enables direct transmission of the audio stream from a TV to the player, for convenient, seamless integration.
The DMP-A6 Gen 2's HDMI output supports Native DSD and audio streams up to 5.1 channels, combining music and home theater for an immersive surround sound experience.
Thanks to the Qualcomm QCC5125 chip, the DMP-A6 Gen 2 offers high-quality, low-latency wireless transmission. It supports Bluetooth SBC and AAC codecs.
The Eversolo DMP-A6 Gen 2 supports NFS, SMB, WebDAC and UPnP protocols, making it easy to retrieve music from storage devices or computers and NAS through simple, intuitive operations.
Bring your CD collection back to life with playback and rip support, easily digitizing and preserving your favorite albums.
CD player / Ripper not included.
The DMP-A6 Gen 2 features HDMI ARC and a trigger. HDMI ARC enables direct transmission of audio from your TV to the DMP-A6 Gen 2, reducing the need for cable connections. The trigger function allows devices to interact with each other, switching on and off automatically. Perfect for home theater systems, it offers a simple, effective audio solution.
Le DMP-A6 Gen 2 introduces the WOL (Wake on LAN) function, allowing you to wake up the device via the application without manual intervention. This feature makes your music accessible anytime, anywhere.
Requires a wired network connection.
Easily control your DMP-A6 Gen 2 from a smartphone or tablet, managing your music library, adjusting settings or selecting your audio sources for an intuitive, personalized user experience.
The DMP-A6 Gen 2's large 6” touchscreen combines convenience and aesthetics. Thanks to its high resolution, playback information and controls remain clear and easily accessible. Whether browsing your music library or adjusting settings, everything is intuitive and fluid.
The chassis is made from precision CNC-machined, aerospace-grade aluminum. Sturdy and elegant, this housing will blend effortlessly into any interior, ensuring durability while protecting components from external interference, guaranteeing pure audio signal transmission.
The DMP-A6 Gen 2 features a number of dynamic meters and spectra to customize the appearance of your player to suit your tastes.
| General specifications | |
| Product type | Audio streamer |
| Screen | Touch screen LCD 6" |
| Internal memory | 4Go GDDR4 + 32go eMMC |
| DAC chips | 2x ESS ES9038Q2M |
| USB interface | XMOS XU316 |
| OPA | OPA1645 |
| SSD slot | M.2 NVME 3.0 2280, supports up to 4TB (SSD sold separately) |
| USB ports | 2x USB-A 3.0 |
| Ethernet | RJ45 (10/100/1000Mbps) |
| Wireless network | WiFi 2.4G+5G dual band |
| Supported sampling rates | PCM up to 32bit 768kHz Native DSD up to DSD512 MQA |
| Supported streaming services | Deezer, Apple Music, TIDAL, Qobuz, Amazon Music, Soundcloud, Presto Music, HIGHRESAUDIO, IDAGIO, Calm Radio, Radios internet, TuneIn, Radio Paradise... |
| Supported network protocols | DLNA, TIDAL Connect, Roon Ready... |
| Control methods & Integration | Mobile app Touchscreen Trigger output Wake On LAN (WoL) |
| Audio inputs & outputs | |
| Bluetooth audio input | Bluetooth 5.0, SBC/AAC support |
| USB-A audio input | Compatibility: Windows 10/11, Mac, Android, iOS Support DSD512, PCM 32bit 768kHz, MQA |
| Coaxial / Optical audio input | Support PCM 24bit 192kHz, DoP64, MQA |
| HDMI ARC input | Support PCM up to 24bit 192kHz |
| USB audio output | Support PCM jusqu'à 32bit 768kHz, DSD512, MQA |
| HDMI audio output | Support PCM 192kHz, multichannel up to 5.1 / Native DSD64 multichannel |
| Optical / coaxial output | Support PCM up to 24bit 192kHz, DoP64, MQA |
| Analog audio outputs | Balanced XLR Single-ended RCA |
| Audio performances | |
| Output level | XLR : 5.2V RCA : 2.6V |
| Frequency response | XLR : 20Hz - 20kHz (±0.15dB) RCA : 20Hz - 20kHz (±0.2dB) |
| Dynamic range | XLR : > 128dB RCA : > 124dB |
| SNR | XLR : > 128dB @ A-wt RCA : > 124dB |
| THD+N | XLR : < 0.00009% (-120dB) RCA : < 0.00011% (-119dB) |
| Crosstalk | XLR : > -125dB RCA : > -124dB |
| Other informations | |
| Supply voltage | 110-240V AC 50/60Hz Max 0.35A |
| Consumption | 13W |
| Dimensions (WxDxH) | 270 x 187 x 90mm |
| Color | Black |
| Package | 1x Eversolo DMP-A6 Gen 2 1x Power cable 1x USB cable 1x Trigger cable |
| Input | Optical |
| Input | HDMI |
| Input | SPDIF |
| Input | Bluetooth |
| Input | WiFi |
| Input | USB |
| Output | HDMI |
| Output | USB |
| Output | RCA |
| Output | Coaxial SPDIF |
| Output | Optical Toslink |
| Output | XLR |
| DAC / ADC Chip | ES9038Q2M |
| Max sampling rate | MQA |
| Color | Black |
| Remote Control | Control app |
| Streaming services & Network protocols | Deezer |
| Streaming services & Network protocols | Tidal |
| Streaming services & Network protocols | Web radios |
| Streaming services & Network protocols | Tidal Connect |
| Streaming services & Network protocols | UpnP |
| Streaming services & Network protocols | Qobuz |
| Streaming services & Network protocols | Amazon Music |
| Streaming services & Network protocols | DLNA |
| Streaming services & Network protocols | Roon / Roon Bridge / Roon Ready |
| Refurbished Grade | Grade B |
