HYPEX FUSIONAMP FA123 Plate NCore Amplifier 2x125W + 1x100W DSP ADAU1450 DAC AK4454 192kHz
The Hypex FusionAMP FA123 plate amplifier can be used to design a two- or three-way active speaker. It is based on two NCore modules capable of developing 2x125W RMS which can also be bridged to form a 1x250W amplifier. There is also a third NCore amplifier delivering 1x100W RMS for a tweeter.
Reference : 13531
499,00 €tax incl.
415,83 € tax excl.
Shipping date: 16-07-2025.
Hypex FusionAMP FA123 FIR
Hypex FusionAMP FA123 Amplificateur NCore Plaque 2x125W + 100W DSP ADAU1450 DCC AK4454 192kHz
The Hypex FusionAMP FA123 plate amplifier can be used to design a two- or three-way active speaker. It is based on two NCore modules capable of developing 2x125W RMS which can also be bridged to form a 1x250W amplifier. There is also a third NCore amplifier delivering 1x100W RMS for a tweeter. This high power allows it to accompany speakers that need a large energy reserve to reveal their potential.
Connectivity & other features
On the connector side, the FA123 offers a balanced analog input and output in XLR 3-pin format and an unbalanced RCA Stereo output. The XLR output is directly connected to the XLR input and therefore allows you to create a chain with several FusionAMPs, the maximum number of modules being limited by the capabilities of your source. Similarly, the amplifier has an AES input and output, the output also being directly connected to the AES input. In addition, there is a SPDIF Coaxial input/output and a Toslink Optical input.
This FusionAMP FA123 integrates a DSP. A USB connector allows you to configure your amplifier via the software specially developed by Hypex. The latter offers many possibilities to adapt your amplifier to your needs, such as creating custom filters.
The front of the amplifier displays a series of 4 status LEDs. The first one is used to warn of a malfunction or when a limit is reached, in order not to damage the equipment.
  • Fixed green : Amplifier power on
  • Blinking green : IR signal received
  • Red / green blinking : Clipping signal
  • Slow green blinking : Mute mode (output not working)
  • Fixed red : DC Error/ Fatal error, amplifier shutdown
  • Red blinking one time per second : High temperature, limited output
  • Red blinking two times per second : Over temperature, output not working
The next 3 LEDs, green, simply display the selected custom profile and therefore in use. To change the profile, simply press the Select button. If the amplifier is in mute mode, then the LED of the selected profile will flash slowly.
1Balanced analog input / output
2Single-ended analog Input
3Mini-USB connector for configuration
4Status LED
5AES input / output
6SPDIF Coaxial input / output
7Optical Toslink output
Operating diagram
Note: In order to protect your speakers, the DSP does not have a filter pre-configured by the manufacturer. A filter must therefore be configured and injected using Hypex Filter Design (HFD) software for the FusionAMP to provide an output signal.
Product typePlate amplifier
Power2x125W + 100W
Inputs1x Balanced 3 poles XLR
1x Single-ended stereo RCA
1x AES
1x SPDIF Coaxial
Outputs1x Balanced 3 poles XLR (direct output)
1x AES
1x SPDIF Coaxial
1x Optical Toslink
DSPADAU1450
DACAK4454
ADCAK5554
SRCSRC4382 - Max sampling rate : 192kHz
SNR AD/DA-109dB
SNR DA-111dB
THD+N AD/DA-100dB @ -1dBFS
THD+N DA-102.5dB @ -1dBFS
Dimensions360 x 120mm
Weight955g
Dimensions
A360mm
B120mm
C55mm
D336mm
E96mm
InputXLR
OutputOptical Toslink
OutputCoaxial SPDIF
Channel2.1
Channel2 (Stereo)
Amplifier chipHypex Ncore
Power (W)125.0
The Hypex FusionAMP FA123 plate amplifier can be used to design a two- or three-way active speaker. It is based on two NCore modules capable of...
