By buying this product you get 34 loyalty points
Mono amplifier module
The NC400 module is a class D mono audio amplifier designed for hi-fi applications. It provides a high power (up to 400W 1% THD with a 4Ω load) and enjoy a benefits from a compact form-factor, allowing varied integrations types.
It is suitable for DIY dual mono audiophile amplifier projects, or for making high performance active speakers.
The circuit is designed so that the signal flows only in a path of discrete component. This helps prevent the uptake of noise from the protection & control system from the onboard microprocessor.
With its current capacity of 22A and its low output impedance(Typ: 0.6 / Max 2.5 ohm), this amplification module is ideal for projects requiring high power without altering or compromising the audio precision.
| Specifications | |
| Technology | NCore |
| Type amplification | Class D |
| Power (2Ω, 1kHz, THD = 1%) | 2Ω, 1kHz, THD = 1%: 580W 4Ω, 1kHz, THD = 1%: 400W 8Ω, 1kHz, THD = 1%: 200W |
| Canals | x1 |
| Audio Input | Molex Microfit header |
| Audio Output | Screw Terminals |
| Operational amplifier | Discreet |
| SMPS voltage +/- | 64V |
| Recommended SMPS | SMPS600 |
| overvoltage protection | 72V |
| Undervoltage protection | 35V |
| yield | Full power: 93% |
| Frequency response | 0 / -3dB, 0-50kHz |
| Weight | 185g |
| Dimensions | Diameter ⌀88mm Height 37mm |
| Package Contents | |
| Module NC400 amplifier | x1 |
| Mount Set NC400 | x1 |
| Cable Set NC400 | Inclued Ncore Signal Cable |
| Manual | x1 |
| Input | PCB Connector |
| Output | PCB Connector |
| Channel | 1 (Mono) |
| Class | Class D / T |
| Amplifier chip | Hypex Ncore |
| Power (W) | 400.0 |
