HYPEX SMPS1200A400 Switching Power Supply Module
The Hypex SMPS1200A400 is a high-efficiency, Safety Class 2 switching power supply designed for use with UcD™, NCORE®, and NCOREx® amplifier modules. This unit is intended for audio systems that require a stable power supply across a wide load range, all in a compact and lightweight form factor.
By buying this product you get 23 loyalty points
Reference : 8574
239,00 €tax incl.
199,17 € tax excl.
Hypex SMPS1200A400 Switching Power Supply Module 1200W 2x63V
Hypex SMPS1200A400
The power supply includes an overcurrent protection mechanism that limits the output current in the event of a temporary overload. It also features balanced auxiliary outputs and a control interface that allows it to be used with UcD™, NCORE®, and NCOREx® amplifier modules.
The SMPS1200 is designed to minimize electromagnetic interference. Its topology and design are optimized to meet the EMI requirements typically associated with professional and high-end audio applications.
The power supply supports a selectable input voltage range, allowing it to operate with different power grid specifications. It is therefore suitable for use in international applications where power grid standards vary.
The SMPS1200 is a two-quadrant full-bridge rectifier designed to power asymmetric Class D amplifiers.
The SMPS1200 complies with current safety and performance standards and is certified for use in professional audio equipment
Hypex SMPS1200A100 diagram
Product typeSwitching mode power supply
Input voltage230V / 115V (switchable via jumper)
Main output voltage2x 49V (Min)
2x 63V (Typ)
2x 72V (Max)
Aux output voltage2x 17V (Min)
2x 22V (Typ)
2x 25V (Max)
Aux output current500mA
Main output power1200W
Switching frequency100kHz
Dimensions165 x 105 x 52mm
Weight750g
ProtectionOvercurrent
InputPCB Connector
OutputPCB Connector
Output voltage (V)63.0
Output current (A)NC
Input voltage (V)250.0
Input voltage (V)120.0
Input voltage (V)100.0
Input voltage (V)190.0
Input voltage (V)130.0
Input voltage (V)210.0
Input voltage (V)240.0
Input voltage (V)95.0
Input voltage (V)230.0
Input voltage (V)110.0
Input voltage (V)200.0
Input voltage (V)220.0
Power SupplySMPS
2 reviews
Excellent
Acheté en remplacement d'une alim similaire cramée après 6 ans de bons et loyaux services suite à une mauvaise manipulation.
Excellente qualité de fabrication, composants de qualité, notice très détaillée. Bien sous tout rapport.
This review has been posted for HYPEX SMPS1200A400 Switching Power Supply Module 1200W 2x63V
Great
Works very well. No pops or clicks through speakers. Manual is not easy for an amateur. But all info is there.
The Hypex SMPS1200A400 is a high-efficiency, Safety Class 2 switching power supply designed for use with UcD™, NCORE®, and...
