TINYSINE TSA3118B Amplifier Module TPA3116D2 Bluetooth aptX TWS 2x50W
This amplifier module from TinySine is based on a TPA3116D2 amplifier chip that can deliver up to 2x50W while offering very good efficiency thanks to its Class D architecture. The module also integrates a Bluetooth AudioB Plus receiver from the brand, supporting the aptX protocol which allows faster and more stable signal transmission.
Reference : 13686
32,91 €tax incl.
27,42 € tax excl.
Shipping date: 22-09-2026.
TinySine TSA3118B
Amplifier Module TSA3118B Bluetooth aptX TWS 2x50W
Module Amplificateur TSA3118B Bluetooth aptX TWS 2x50W
This amplifier module from TinySine is based on a TSA3118B amplifier chip that can deliver up to 2x50W while offering very good efficiency thanks to its Class D architecture. The module also integrates a Bluetooth AudioB Plus receiver from the brand, supporting the aptX protocol which allows faster and more stable signal transmission. The TSA3118B can be used to accompany passive speakers with an impedance of 4 or 8 Ohm.
The module can also be used in TWS mode. The latter allows you to wirelessly pair 2 of these amplification modules and therefore enjoy a dual mono system. The 3-pin audio output connector can also be used to connect a Subwoofer amplifier module. The BVC port allows it to connect a volume control module such as the TinySine TSA1000 or TinySine TSA1020.
The amplifier automatically detects the AUX and line inputs as well as Bluetooth, the latter having a higher priority. When the Bluetooth source is disconnected or paused, the amplifier automatically switches to the AUX / Line input.
TSA3118 & TSA1000. Modules
 Amplify Module TSA3118B Bluetooth aptX TWS 2x50WMany TSA3118 modules can be connected together to create a multi-channel amplifier. The 3-pin audio output connector can also be connected to a Subwoofer module.
Operation of two modules in TWS mode
  • S1 : Long press (3s) to activate Bluetooth pairing mode / Long press (6s) to reset pairing information.
  • S1 + S2 : Long press (1s) to switch the module to slave TWS
  • S1 + S3 : Long press (1s) to switch the module to master TWS
  • S2 + S3 : Long press (1s) to cancel the TWS connection
Product typeAmplifier module TPA3116D2
Bluetooth version4.2
Supported Bluetooth protocolsaptX, aptX Low Latency, SBC, AAC
TWS SupportYes
BVC port for volume controlYes (x1)
Automatic input detectionyes
ProtectionsOver/Under voltages, overload, thermal protection
Dimensions103 x 69 x 25mm
Mounting holes59 x 86mm
Max Height20mm
Measurement
ParametersConditionsMin.Typ.Max.
Efficiency50W @ 4 Ohm87%-90%
Minimum impedance-3.2 Ohm--
Gain-24dB25dB26dB
Input sensitivity (RMS)@ 4W, 50W, 1kHz-808mV-
Input impedance--22 kOhm-
Output power@ 4 Ohm, THD+N = 1%-36W-
@ 4 Ohm, THD+N = 10%-50W-
Frequency response@ ±3dB, 4 Ohm20Hz-20kHz
THD@ 4 Ohm, 1W, 1kHz-0.0299%-
Power supply voltage@ 4 Ohm, 10W, 1kHz-0.073%-
-10V DC21V DC24V DC
OutputPCB Connector
OutputScrew terminals
Channel2 (Stereo)
Amplifier chipTPA3116D2
Power (W)50.0
3 reviews
Nickel !
Vraiment très content de cet ampli ! Pour ma part je l'ai enfermé dans une boite de dérivation et posé au dessus du plafond de ma salle de bain. Il est couplé avec les HP vendus également par Audiophonics: les DAYTON AUDIO ME620C (35W) qui sont juste parfaits en rendu, en qualité et correspondaient à mon besoin d'HP encastrables. Comme expliqué précédemment dans un autre avis, le fait qu'il y a deux bips au démarrage peut être dérangeant. Pour ma part je le laisse constamment alimenté, avec le transfo vendu justement par Audiophonics le FX-Audio 24 Volts 4A à 22€.(lui aussi caché au dessus du plafond pour le coup)
This review has been posted for TINYSINE TSA3118B Amplifier Module TPA3116D2 Bluetooth aptX TWS 2x50W
Très bien
Installer dans une enceinte portable diy sur 2 haut parleurs de 35w. Parfait juste un très léger grésillement quand il n'y a pas de musique mais seulement audible avec un silence total.
Excellent
L'ampli fonctionne très bien. Le bluetooth n'injecte aucun parasite dans les HP (peut-être parce le module n'est pas intégré directement dans les circuits de la carte, simplement "pinoché"). Il y a un léger souffle (normal en audio) dans les HP lorsqu'il n'y a pas de musique, mais qui disparait lorsque la musique est lancée, même à très faible volume.
J'ai aussi connecté en RCA (avec de simples coupleurs en amont) un lecteur CD et une platine vinyle disposant déjà d'un pré-ampli.
Ça fonctionne très très bien.
Côté puissance, il est presque trop puissant pour mes HP de 40W sous 4 Ohms.
Enfin, il ne semble pas vraiment chauffer même après plusieurs heures d'utilisation.
Seul bémol : il fait un "double bip" assez fort (limite gênant) à l'allumage. Et l'usage d'un contrôleur de volume numérique TINYSINE TSA1020 (connecté en bluetooth -connecteur blanc- et en RCA), introduit quelques minis parasites dans les HP. De même cela disparait avec la musique.
Après une mauvaise expérience d'un ampli d'une autre marque (bruits importants dans les HP, etc.) sur le site, je suis très satisfait de ce second achat.
This amplifier module from TinySine is based on a TPA3116D2 amplifier chip that can deliver up to 2x50W while offering very good efficiency...
