WONDOM AA-AB32321 Class D Amplifier Module IRS2092 2x87W 8 ohm
The WONDOM AA-AB32321 is a high-power Class D stereo amplifier module based on the Infineon IRS2092 controller, specifically designed for DIY Hi-Fi applications requiring substantial power reserves and excellent efficiency. Powered by a symmetrical supply ranging from ±45V to ±60V DC (±50V recommended), it delivers up to 2x125W into 8Ω at 10% THD+N or 2x87W into 8Ω at 1% THD+N.
Reference : 22267
39,90 €tax incl.
33,25 € tax excl.
Shipping date: 20-11-2026.
WONDOM AA-AB32321 Class D Amplifier Module IRS2092 2x87W 8 Ohm
WONDOM AA-AB32321
The WONDOM AA-AB32321 is a high-power Class D stereo amplifier module based on the Infineon IRS2092 controller, specifically designed for DIY Hi-Fi applications requiring substantial power reserves and excellent efficiency. Powered by a symmetrical supply ranging from ±45V to ±60V DC (±50V recommended), it delivers up to 2x125W into 8Ω at 10% THD+N or 2x87W into 8Ω at 1% THD+N. The module offers high efficiency ranging from 85% to 90%, a frequency response from 20Hz to 20kHz, a typical gain of 31dB, an input impedance of 100kΩ, and an input sensitivity of 839mVrms to reach its rated output power. It features stereo RCA inputs, screw terminals for power supply and speaker outputs, as well as a Shutdown control input. Its design includes a power indicator, overcurrent protection, thermal protection, undervoltage and overvoltage protection, and an optimized heatsink. The module supports a minimum load impedance of 8Ω, consumes approximately 6W at idle, can deliver up to 5.9A at full power, and comes in a 152.4 x 114.3 x 63.5mm format with a weight of approximately 579g.
WONDOM AA-AB32321
Technical Specifications
Product TypeAmplifier Module
ClassClass D
Amplifier ChipIRS2092
Inputs1x Stereo Input via RCA
Outputs1x Stereo Speaker Output via Screw Terminal
Gain31dB
Input Sensitivity839mV @8Ω, 125W, 1KHz
Input Impedance100Kohms
Output Power2x 87W @8Ω THD+N 1%
2x 125W @8Ω THD+N 10%
Bandwidth20Hz-20kHz @8Ω, ±3dB
THD0.023% @8Ω, 1W, 1KHz
0.054% @8Ω, 10W, 1KHz
Noise Level244µV
SNR96dB @87W 8Ω THD+N 1%
Minimum Load Impedance8Ω
Power Supply±45 / ±50 / ±60 VDC (Typ.: ±50)
Idle Power ConsumptionTyp.: 6W
Max.: 12W
Max. Current5.9A @ 250W 6Ohm
Efficiency85-90% @ 125W @ 8Ohm
Switching Frequency232/285kHz
Undervoltage Protection39V
Overvoltage Protection68V
Overtemperature Protection100°C
Dimensions152.4 x 114.3 x 63.5mm
Weight579g / 1.28lbs (±10%)
Package Contents1x WONDOM AA-AB32321
OutputScrew terminals
Channel2 (Stereo)
Amplifier chipInfineon IRS2092
Power (W)87.0
The WONDOM AA-AB32321 is a high-power Class D stereo amplifier module based on the Infineon IRS2092 controller, specifically designed for DIY Hi-Fi...
