WONDOM JAB3+ Amplifier Board
The Wondom JAB3+ is an amplifier module capable of delivering 1x100W of power, supporting Bluetooth 5.0 (aptX HD) and incorporating an ADAU1701 DSP for an all-in-one audio solution. Thanks to this DSP, JAB3+ can be programmed with SigmaStudio and controlled via an intuitive graphical interface (requires the use of a Wondom ICP5 module, not supplied).
Reference : 20656
58,56 €tax incl.
48,80 € tax excl.
Shipping date: 20-11-2026.
Wondom JAB3+ Class D Amplifier Board Bluetooth 5.0 DSP ADAU1701 1x100W 4 Ohm
Wondom JAB3+ : Vue de face
Wondom JAB3+: Bluetooth 5.0
The JAB3+ is equipped with a Bluetooth 5.0 module for audio input that supports the aptX, aptX HD, aptX LL, SBC and AAC protocols. This module directly integrates an antenna, so you can pair the JAB3+ directly with the source of your choice to listen to music. An external antenna port is also available on the board to ensure a stable connection in cases where the JAB3+ is installed in a driver or other location requiring the antenna to be offset.
Wondom JAB3+ : Bluetooth 5.0 Module
Wondom JAB3+ : DSP ADAU1701
Wondom JAB3+: DSP ADAU1701
The JAB3+ also incorporates a high-performance ADAU1701 DSP chip for audio signal processing. Four ports for external potentiometers are fitted to the JAB3+. You can use external potentiometers to control volume, gain and frequency response.
Once connected to the WONDOM ICP5 programmer, you can write a program with SigmaStudio, or get real-time control of your audio systems via the PC user interface, where you can adjust gain, volume, high/low pass filter, EQ and other parameters.
Miumax Application
Wondom JAB3+: Jack 3.5mm line input
Furthermore, in addition to the Bluetooth input, the JAB3+ has a 3.5mm jack line input. Note that when the two inputs are used simultaneously, the signals are mixed before being sent to the amplification circuit.
Wondom JAB3+ : Line input 3.5mm jack
Wondom JAB3+ : Mounting for battery supply
Wondom JAB3+: Battery powered
Moreover, the JAB3+ supports battery power, making it ideal for use on the move. Please note, however, that the JAB3+ is not equipped with a charge management circuit, so we recommend using a battery management module such as the Wondom BCPB6.
Wondom JAB3+: 4 external potentiometers
Four external potentiometer ports are fitted to the JAB3+ for easy control of the entire audio system. You can use them to control gain or crossover frequency with ease. The functions of these potentiometers adjust automatically according to the output mode.
Wondom JAB3+ : port for potentiometers
Wondom JAB3+: Automatic standby mode
The JAB3+ uses a signal level detector to reduce power consumption. It constantly monitors the input signal and there is a pre-set signal voltage threshold. If no signal is detected (voltage below threshold) for 5 minutes, the amplifier module will automatically go into standby mode, reducing power consumption. Similarly, when a signal is detected in standby mode, the module will automatically reactivate.
Product typeAmplifier module
Number of channels1 (Mono)
Inputs1x Line input 3.5mm jack
Bluetooth 5.0
OutputsSpeaker terminal block
1x Line output PH2.0
Supported Bluetooth codecsaptX, aptX HD, aptX LL, SBC, AAC
Minimum load impedance2Ω
Efficiency78%
Amplifier gain26dB
Input sensitivity775mV
HFP cut-off frequency0.25kHz - 2kHz
LFP cut-off frequency20kHz
Signal-to-noise ratio (SNR)99dB
Total harmonic distortion more noise (THD+N)0.04% @5W 2Ω
0.06% @10W 2Ω
Input impedance10kΩ
Output noise level174µV
Power supply voltage12V-26V DC
Dimensions91.44 x 68.6mm
PackageWondom JAB3+
1x Power cable Molex-2Pos 50cm
1x Speaker cable Molex-4Pos 50cm
InputJack 3.5mm
OutputPH 2.0mm
OutputSpeaker terminal
Channel1 (Mono)
Amplifier chipN/A
Power (W)100.0
WONDOM JAB3+ Class D Amplifier Board Bluetooth 5.0 DSP ADAU1701 1x100W 4 Ohm
The Wondom JAB3+ is an amplifier module capable of delivering 1x100W of power, supporting Bluetooth 5.0 (aptX HD) and incorporating an ADAU1701 DSP...
