WONDOM AA-AB32167 Class D Amplifier Module TPA3123 2x19W 4 Ohm
The WONDOM AA-AB32167 is a Class D stereo amplifier module based on the Texas Instruments TPA3123 chip, designed for DIY audio projects, active speakers, multimedia systems, and OEM integrations. Powered by a DC supply voltage ranging from 10V to 30V DC, it delivers up to 2x19W into 4Ω at 1% THD+N and can reach 2x25W into 4Ω at 10% THD+N with a 27V power supply.
Reference : 22263
22,90 €tax incl.
19,08 € tax excl.
Shipping date: 24-11-2026.
WONDOM AA-AB32167
The WONDOM AA-AB32167 is a Class D stereo amplifier module based on the Texas Instruments TPA3123 chip, designed for DIY audio projects, active speakers, multimedia systems, and OEM integrations. Powered by a DC supply voltage ranging from 10V to 30V DC, it delivers up to 2x19W into 4Ω at 1% THD+N and can reach 2x25W into 4Ω at 10% THD+N with a 27V power supply. Thanks to its Class D architecture, it offers high efficiency ranging from 90% to 95%, reducing power consumption and heat generation. The module features analog stereo audio inputs, a 22kΩ input impedance, 635mV RMS input sensitivity, and a frequency response from 20Hz to 20kHz. It also integrates a power LED, overcurrent and overtemperature protection circuits, as well as optimized thermal dissipation through the PCB's large copper areas. Compact, with dimensions of 91 x 69 x 16.5mm (3.60" x 2.70" x 0.65") and a weight of approximately 167g, it can be easily installed thanks to its four mounting holes. The AA-AB32167 therefore represents a high-performance, reliable, and cost-effective stereo amplification solution for a wide range of audio applications requiring moderate output power and excellent energy efficiency.
WONDOM AA-AB32167
WONDOM AA-AB32167 Overview
1Stereo RCA Analog Input
2Stereo Analog Input via Solder Pads
3MUTE/STBY (Solder Pad)
410-30V Power Supply (Solder Pads)
5Stereo Speaker Output
610-30V Power Supply (DC Jack or Screw Terminal)
Technical Specifications
Product TypeAmplifier Module
ClassClass D
Amplifier ChipTPA3123
Inputs1x Stereo Input via RCA
1x Stereo Input via Solder Pads
Outputs1x Stereo Speaker Output via Screw Terminal
Gain25dB
Input Sensitivity635mV @4Ω, 25W, 1KHz
Input Impedance22Kohms
Output Power2x 19W @4Ω THD+N 1%
2x 25W @4Ω THD+N 10%
Bandwidth20Hz-20kHz @4Ω, ±3dB
THD0.02% @4Ω, 1W, 1KHz
0.06% @4Ω, 10W, 1KHz
Noise Level103.68µV
SNR91dB @19W 4Ω THD+N 1%
Minimum Load Impedance3.2Ω
Power Supply10-30V DC (27V typ.)
Idle Power Consumption0.8-1.6W
Standby Power Consumption0.16-0.4W
Max. Current2A @ 50W 4Ohm
Efficiency90-95% @ 25W 4Ohm
Switching Frequency250kHz
Dimensions91 x 69 x 16.5mm
Weight167g / 0.37 lbs (±10%)
Package Contents1x WONDOM AA-AB32167
InputSolder pad
OutputScrew terminals
Channel2 (Stereo)
Amplifier chipTPA3123
Power (W)19.0
The WONDOM AA-AB32167 is a Class D stereo amplifier module based on the Texas Instruments TPA3123 chip, designed for DIY audio projects, active...
