AECO ABC-1451 BNC Connectors 50 Ohm Beryllium Copper Gold Plated Ø10mm (Pair)
The aeco ABC-1451 are 50Ω BNC connectors featuring a very high quality design. They feature high-purity beryllium copper contacts with 10µ gold plating, providing excellent conductivity and protection against oxidation.
Reference : 18040
89,00 €tax incl.
74,17 € tax excl.
aeco ABC-1451
Connecteurs BNC 50 Ohm Cuivre Beryllium Plaqué Or (La paire)
aeco ABC-1451 Connecteurs BNC 50 Ohm Cuivre Beryllium Plaqué Or (La paire)
The aeco ABC-1451 are 50Ω BNC connectors featuring a very high quality design. They feature high-purity beryllium copper contacts with 10µ gold plating, providing excellent conductivity and protection against oxidation. The body is made of brass to make the connector extremely robust. The cable, with a maximum diameter of Ø7.5mm, can be fitted by soldering or crimping.
Product typeBNC connectors
Contacts materialBeryllium copper (purity: ≥ 97%)
Contacts platingGold 10µ
ShellBrass
Impedance50Ω
Frequency range1GHz
VSWRUp to 1.2
Contact resistance< 0.1mΩ
Max cable diameterWith reducer: Ø8.5mm
Without reducer: Ø10.5mm
Total dimensionsØ14.5*42mm
Quantity2 connectors
Max cable diameter (mm)10.5
Mounting typeTo weld
Mounting typeTo crimp
ConnecticMale
Max panel thickness (mm)N/A
Impedance (Ω)50
Contacts Material (Connector)Beryllium Copper
The aeco ABC-1451 are 50Ω BNC connectors featuring a very high quality design. They feature high-purity beryllium copper contacts with...
