By buying this product you get 119 loyalty points
Subwoofer 500W (Unit)
The Rafale VR2-25 kit from Atohm is an active subwoofer very high performance. Its bass-reflex load carries a 500Weff generative amplification coupled to a duo of exceptional speakers with a diameter of 23cm. With its many connection options, this box can be integrated without limitation in all HiFi and Home Cinema installations. It is the ideal complement to all types of speakers, from library models to large columns. It is the natural extension of this technology to the lowest frequencies, with exceptional accuracy, dynamics and depth.
| Specifications | |
| Product type | Speaker kit |
| Speaker type | Subwoofer |
| Load | Bass Reflex 52L |
| Frequency response | 28Hz - 150Hz |
| Power (RMS) | 500Wrms |
| Low level inputs | 2x RCA |
| High level input | 2x Banana plugs 4mm / Direct tightening |
| Cutout frequency | Adjustable from 38Hz to 150Hz |
| Phase control | 0-180° |
| Filter slope | Adjustable 12dB-24dB-LFE |
| Bass/Medium driver | LD230TDR08 (x2) |
| General | |
| Supply voltage | 115V / 230V |
| Consumpation | 700Wmax |
| Dimensions | 320*550*440mm (L*H*P) |
| Weight | 32kg |
