Power Connector Type B Pure Copper Plated Silver / Gold 24k Ø19mm
The Viborg VM503G Type B power connector offers excellent design quality and will allow you to design high-end mains cables to properly power your HiFi system. The connector's contacts are made of pure Copper, a material that provides excellent electrical conductivity. These contacts benefit from a triple plating of OFC Copper, Silver and 24k Gold to maximize conductivity while improving their resistance to oxidation.
The body of the connector is made of Bayer-2805 Polycarbonate. The conductors are simply inserted into the connector by means of a screw system that holds the conductors firmly in place.
| Specifications | |
| Product type | Type B power connector |
| Contacts material | Pure copper |
| Contacts plating | OFC Copper Silver 24k Gold |
| Body and contacts support material | Polycarbonate Bayer-2805 |
| Mouting type | To screw (hex screws) |
| Max conductor diameter | Ø8mm |
| Min/Max cable diameter | Ø6mm / Ø19mm |
| Voltage / Current | 125V 15A |
| Total dimensions | 77 x Ø40mm |
| Color | Black |
| Max cable diameter (mm) | 19.0 |
| Mounting type | To screw |
| Connectic | Male |
| Connector | Type B (NEMA) |
| Contacts Material (Connector) | Copper |
| Contacts Plating (Connector) | Silver |
| Contacts Plating (Connector) | Gold |
| Rated current (A) | 15.0 |
